Fujitsu Siemens Intel Computer Stuck at BIOS, F2/F12 Options Not Working
wsklovers 7226 4
  • #1 6696002
    wsklovers
    Hello all. Some time ago my computer crashed, so I have to use a replacement, but now it starts to fail, so I decided to take on the reactivation of the previous one. :)
    when it is turned on, only the message appears: F2 Bios Setup / F12 Boot Menu and a bar that loads up to about 75%. Nothing happens yet. After pressing F12 the system management configuration changed or problem occurred and info about bios (pxoenix bios version 4.06).
    When I press F2, it's just what I am saying when I press F12: entering setup ... and then nothing else happens.
    I also noticed that the Prock windmill stopped spinning because I did not get electricity so I connected it somewhere else
     What can be a problem, which can be broken. If anyone has any idea, please ask for a hint.
    Change the thread's title into the regulation - reg. p. 11
    Post correct. You use diacritics or you do not use them at all!
    mat_ed
  • #2 6696005
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    Provide full configuration of this computer.
  • #3 6696072
    wsklovers
    Fujitsu siemens with Intel Pentium 4 2.8 GHz processor, 512 Mb Ram DDR. What else do you give ??
    Change the title of the thread. Your next request will not be!
    mat_ed
  • #4 6696249
    Manfred48
    Help: 11
    Rate: 31
    I also noticed that the Prock windmill stopped spinning because it did not get electricity so I connected it somewhere else
    And that can be a problem. The board checks whether the processor has adequate cooling if it does not have it stops the boot. Try replacing the windmill with the same or similar speed control (3 wires). Did you reset the BIOS?
    P.S. Do what he asks for mat_ed.
  • #5 6696254
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    The model of the motherboard would be useful. But do the following now:
    1. Disconnect disks and drives (CD, DVD, floppies) from the motherboard and try to start the computer.
    2. Reset the BIOS (by removing the battery from the motherboard for several seconds), then try to start the computer.
    3. Watch the motherboard if there are no swelling capacitors on it (as in this topic - https://www.elektroda.pl/ rtvforum / topic1221090.html .
    Share with us what effects you have obtained.
