Computer Turns On, Fans Spin, HDD Lights Up, but BIOS Won't Start: Reset & Battery Removal Tried
Setka933 6615 12
Why does a newly assembled PC power on with spinning fans and HDD activity but show no BIOS image on the monitor even after clearing CMOS?
Check whether the processor is supported by the motherboard, because the thread points to CPU incompatibility as the likely cause of the no-POST/no-display behavior [#16670659] [#16670729] For the Asus P5E3, the Intel Celeron D 346 3.06 GHz was identified as not being on the supported list [#16670659] [#16670729] If the CPU is unsupported, the board may power up with fans and drive activity but still not start properly or show anything on screen [#16670729] The replies also suggest verifying the system speaker, since no beep codes were heard [#16670664] [#16670666]
  • #1 16670574
    Setka933
    As in the subject, I started to assemble the computer, I had some parts, I bought some. Everything folded and the computer starts. All windmills the fans are spinning, d and the ode on the disc is lit, but nothing is displayed on the monitor. I will add that reset bios I made the BIOS with the jumper and by pulling the battery out and , it doesn't do anything.
  • #2 16670592
    Kasek21
    Help: 4981
    Rate: 3547
    Full computer configuration including the make and model of the power supply ?!
  • #3 16670612
    Setka933
    Asus p5e3 motherboard
    Intel celeron 3.6 processor
    nvidia geforce gtx 275 graphics card
    120GB Samsung disk
    framework Kingston 4GB RAM
    Corsair vs 550 power supply in IN
    Added after 9 [minutes]:
    I will add that everything works on another disc.
  • #5 16670664
    badboy84
    Help: 1197
    Rate: 1486
    System speaker connected?
  • #6 16670666
    Setka933
    Yes it is connected. Does not make any sounds.
    Everything is connected, under pressure as it should be.
    Is it possible that it's through an outdated processor?
    I have improved the spelling of your posts. Take care of her, please.
    I also remind you that the sentences begin with a capital letter and end with a full stop.
    RADU23
  • #7 16670686
    badboy84
    Help: 1197
    Rate: 1486
    Enter the model of this processor or check if it is on the supported list. A colleague posted the link above.
  • #8 16670721
    Setka933
    The processor is intel celeron d 346 3.06 GHz, unless it is not on the supported list
  • #9 16670729
    badboy84
    Help: 1197
    Rate: 1486
    Well, no, the CD will not move if the processor is not supported by it. You must have a processor on the list.
    It is not known what you expect from this computer, budget is the Core 2 Duo E8400 to buy for about 20 PLN but that's another topic.
  • #10 16689723
    Setka933
    When trying to install, a message about bootmgr missing appears
    I want to reinstall Windows 7, the disc is bootable because the system was already installed from it.
    I set up disk booting and disk in the second position. Can you tell me what to do, where I made a mistake, how to set up the bios? On each disc with windos there is the same message. I read on different forums, but everywhere the same and nothing helps.
    Thanks in advance for your help.
  • #11 16689786
    Kasek21
    Help: 4981
    Rate: 3547
    What was the system before? Partitions are not in GPT mode?
  • #12 16689796
    Setka933
    The same as what I'm trying to install now, but it didn't work before so I decided to reinstall the system. In Bios I have IDE set up for that, I'm a bit green in these matters so please be understanding.
  • #13 16690382
    310artur
    Help: 980
    Rate: 670
    Is the drive OK? At startup try F8 and select the drive from the list - you will force boot from the disc regardless of the boot setting in the BIOS.
The discussion revolves around a computer assembly issue where the system powers on (fans spin, HDD lights up) but fails to display anything on the monitor. The user has attempted to reset the BIOS using a jumper and by removing the battery, but the problem persists. The computer configuration includes an Asus P5E3 motherboard, Intel Celeron D 346 processor, Nvidia GeForce GTX 275 graphics card, 120GB Samsung HDD, and Kingston 4GB RAM, powered by a Corsair VS 550 power supply. Suggestions include verifying CPU compatibility with the motherboard, ensuring the system speaker is connected, and checking the boot settings in BIOS. The user later encounters a "bootmgr missing" error while trying to reinstall Windows 7, prompting further inquiries about BIOS setup and drive status.
TL;DR: 0 beep codes with spinning fans usually means a no-POST condition; "You must have a processor on the list." [Elektroda, badboy84, post #16670729]
Why it matters: This FAQ helps builders fix a PC that powers on but won’t show BIOS or install Windows, fast.
Why does my PC power on but the BIOS won’t start?
Your symptoms match a no-POST condition. On the Asus P5E3 build, members flagged CPU compatibility as the top cause. If the processor isn’t on the supported list, the board will not start. The silent speaker reinforces no-POST. Check the CPU list first, then reseat parts only after confirming support. "CPU must be on the list." [Elektroda, badboy84, post #16670729]
Is the Intel Celeron D 346 supported by the Asus P5E3?
In the thread, the builder identified a Celeron D 346, and a responder stated the board will not start if the CPU isn’t supported. The guidance was to verify against the Asus CPU support list and replace the chip if absent. This mismatch explains power-on with no BIOS screen. [Elektroda, badboy84, post #16670729]
What first checks should I do for a no-POST PC?
Confirm the speaker is connected, then power on and listen for beeps. Recheck 24‑pin and 8‑pin CPU power, GPU power, and display cable. Try one RAM stick. Clear CMOS once. These steps mirror the case where fans and HDD LED worked but there was no display. [Elektroda, Setka933, post #16670574]
How do I clear CMOS correctly on this kind of build?
  1. Power off and unplug the PSU.
  2. Move the CLRTC jumper to the clear position (or remove the battery) for 10–30 seconds.
  3. Restore the jumper (or battery), plug in, and boot. The OP tried both jumper and battery methods; use only one clean attempt. [Elektroda, Setka933, post #16670574]
Do I really need the tiny system speaker?
Yes. It provides POST beep codes that pinpoint faults. Without it, you lose key diagnostics. In the thread, a helper asked specifically about the speaker to confirm beeps, because silence narrows causes toward CPU or board issues. Connect it before further testing. [Elektroda, badboy84, post #16670664]
What budget CPU should I try if mine isn’t supported?
A respondent suggested the Core 2 Duo E8400 as a cheap drop‑in for testing. It was available around 20 PLN, making it a practical compatibility probe. Swapping to a supported CPU often restores POST immediately if the board is fine. [Elektroda, badboy84, post #16670729]
Everything spins and HDD LED blinks; does that prove my PSU and GPU are fine?
It suggests power is present, but it doesn’t prove full health. In the case discussed, similar symptoms occurred despite proper power and a discrete GPU. Prioritize CPU support and POST beeps before assuming PSU or GPU failure. [Elektroda, Setka933, post #16670574]
My build worked on another disk. What does that tell me?
That points away from a PSU or GPU fault and toward configuration or compatibility on the current setup. The OP noted everything worked on a different disk, indicating the core hardware can run, but the present combination still failed to reach BIOS due to CPU support concerns. [Elektroda, Setka933, post #16670612]
How do I fix “BOOTMGR is missing” when installing Windows 7?
Force boot from your install media. Restart, press F8, and select the optical drive from the one‑time boot menu. This bypasses a mis‑ordered boot list and starts the installer. If the message persists, recreate the media. [Elektroda, 310artur, post #16690382]
What does the “BOOTMGR is missing” error actually mean here?
It indicates the system tried to boot from a drive without valid boot files, not from the installer. The thread’s builder saw it on multiple discs, implying boot order or forced boot selection was the fix path rather than media failure. [Elektroda, Setka933, post #16689723]
Could outdated BIOS settings be the reason Windows setup won’t start?
Yes. Wrong boot priority or disabled optical drive can block the installer. Use the one‑time F8 boot menu to confirm the disc starts, then adjust BIOS boot order after installation completes. This method was advised in the thread. [Elektroda, 310artur, post #16690382]
Why are there no beep codes even though the speaker is connected?
Silence during POST often points to CPU incompatibility or a failed motherboard. In the discussed case, the speaker was connected yet silent, which aligned with an unsupported CPU on the Asus P5E3. "The board will not move if the processor is not supported." [Elektroda, badboy84, post #16670729]
