HP 250 G4: Unable to Enter BIOS - Need Help with Key Combinations & Troubleshooting
makaronmc 25005 7
  • #1 17131686
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Hello gentlemen...
    I'm trying all possible combinations ... and I can not enter the BIOS :(
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. When starting the HP logo, press F1 or F10. And still depends which year of this HP is then at the start to quickly press F10.
  • #3 17131793
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    The BIOS came in, but I can not run the Windows 7 installer from the DVD: /
    What am I doing wrong ?
  • #4 17131821
    Pedros050
    Help: 2471
    Rate: 3927
    OS boot manager not set to CD / DVD ROM.
  • #5 17131826
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    I can only change the order, the arrow is assigned to the OS Boot Manager
  • #6 17131845
    Pedros050
    Help: 2471
    Rate: 3927
    And turn off USB BOOT. Of course, the disc in the drive yes and after the approval does not start from the disc?
  • #7 17131965
    makaronmc
    Level 30  
    Help: 7
    Rate: 240
    Did not help :(
  • #8 17134064
    Sokal2
    Level 19  
    Help: 38
    Rate: 71
    you have to disable the "secure boot" function and it is best to boot in "legacy" mode, not UEFI in the case of OS7 installation, the Biosu enters the F10 boot menu: F9, POST MENU: ESC. greetings
The discussion revolves around difficulties entering the BIOS on an HP 250 G4 laptop. Users suggest pressing F1 or F10 during the HP logo screen to access the BIOS. Once in the BIOS, the author encounters issues booting from a Windows 7 installation DVD, with suggestions to check the OS boot manager settings, disable USB boot, and ensure the DVD is in the drive. Additionally, it is recommended to disable "secure boot" and switch to "legacy" mode instead of UEFI for successful installation.
