Dishwasher Placement Near Gas Stove/Oven: Safety & Heat Impact on Appliances
heniq60 69311 16
Can a dishwasher be installed directly next to a gas stove/oven, or does it need heat insulation and spacing?
A dishwasher can be placed next to a stove/oven, but not ideally in direct contact; if you can leave about 5–10 cm spacing, that is considered safe by one reply, and hoses/pipes should not touch and are best laid low behind the units [#6741694] If the appliances must be closer than about 3 cm, Electrolux instructions cited in the thread recommend inserting a 1 cm thick non-flammable insulation board between them [#6742898] The recommended insulation is a non-flammable fireplace-style board made of mineral fibers, not a reflective radiator mat or ordinary polystyrene, because polystyrene can melt and even catch fire [#6743022] [#6743436] Some users reported acceptable results with smaller gaps such as 4.5 cm or even direct adjacency on newer, well-insulated appliances, but those were anecdotal and depended on the stove model [#6741802] [#6767666]
  • #1 6741656
    heniq60
    Rate: 19
    Hello everyone !
    I just bought a dishwasher, the problem is that I have a small kitchen and the dishwasher would have to stand directly by the stove.
    Therefore, I have a question: is such a neighborhood acceptable, will it not affect the failure rate due to high temperature.
    If such a location of the equipment is not an option, is it possible to put at least a drain hose outside the stove?
  • #2 6741694
    Szczepaniii
    Rate: 26
    This can be dangerous if the dishwasher is sticking to the oven.
    5-10cm spacing between these devices and I see no cause for concern.
    The pipes, if they have to be behind the kitchen, are the same principle so that they do not touch, are separated, and preferably lay on the ground (warm air rises, the floor should be cold).
    Regards
  • #3 6741757
    heniq60
    Rate: 19
    Thanks !
    The problem is that it would have to be in direct contact (170cm x 275cm kitchen). I suspect, however, that the devastation and remodeling of furniture will not pass me by.
  • #4 6741802
    roobert
    It is best to check the temperature of the adjacent wall when using the oven and then make a decision.
    For me, the dishwasher has been "pressed" between the wall and the gas stove for two years and no problem.
    Maybe because the stove is quite new and has good insulation. In any case, when the oven is running for a long time, the side wall of the hob is lukewarm so no problem.
  • #5 6741839
    heniq60
    Rate: 19
    Unfortunately, it heats up quite a lot, the oven is just about 2 hours long. and just when touched it almost burns !!!!! (the stove is 15 years old).
    On the other hand, the side of the sink unit that touches it is warm.
    Regards.
  • #6 6741859
    Szczepaniii
    Rate: 26
    The fact depends a lot on the type of oven.
    But with a grandmother baked at 180 degrees C for an hour, I doubt a bit about the cold walls of what this device would be like.
    I sincerely recommend reading the instruction manual ... of a newer refrigerator, there is usually a description of what kind of a refrigerator can be used when the refrigerator must stand next to the stove with a stove, and specifically I mean some insulating material inserted between these devices (I do not remember what it was), if you do not have such a possibility, please write it, I will look for a manual, I will put it here.
  • #7 6741982
    heniq60
    Rate: 19
    Thanks a lot!
    I would be grateful for the information, unfortunately I have to go off duty, and I don't have internet there.
    I'm not just Henryk.
    Regards.
  • #8 6742898
    Szczepaniii
    Rate: 26
    I found Electrolux instructions and it is written there and for a distance of 3 cm and less, insert a non-flammable insulation board with a thickness of 1 cm. We did not discover America here because they did not write what, I will look at work tomorrow I have more such funny papers there :) and possibly who to ask.
  • #9 6743022
    dual
    Help: 34
    Rate: 72
    It is enough to insert a non-flammable insulating board, the same as for the internal insulation of fireplaces. There are such boards for pieces in Castorama or plumbing stores. Good luck
  • #10 6743225
    hubertus 1
    Help: 7
    Rate: 8
    in my case, the stove has been adjacent to the dishwasher for almost a year. I have not used any isolation between them. I would like to add that my kitchen is a hot-air amica, fully electric, dishwasher built-in, so ventilation is very small. From what I observed, the dishwasher has its insulation, as well as the stove, and I have all the controls in the door. The dishwasher is on duty almost every day. Coming back to insulation, wouldn't an ordinary mat with thermal reflection such as is used under radiators not be enough in this case? It is not thick and you would not have to move the equipment apart too much. Maybe it would be enough?
  • #11 6743436
    dual
    Help: 34
    Rate: 72
    A reflective plate, the so-called radiator plate, is made of polystyrene, which melts easily and can even catch fire, so it's better not to risk it. Fireplace plates are made of non-flammable mineral fibers, so they provide much better protection.
  • #12 6743523
    tonk07
    Help: 21
    Rate: 58
    The dishwasher heats up too, the highest programs are 70 ° C so I would not bother too much. If the stove does not catch fire, the dishwasher will be fine ;) It is a bit different with coolers, they do not cool them down to heat them up. But if you are afraid, you can insert insulation or make a slot so that they do not touch each other.
  • #13 6746365
    Szczepaniii
    Rate: 26
    That's right, but my friends said that it is best to use a plate that insulates fireplaces, cost about PLN 50 per piece, one is enough and conscience clean :)
    Regards
    Stephen
  • #14 6767666
    heniq60
    Rate: 19
    Hello !
    Thanks a lot for the hints. I found 4.5 cm and moved the dishwasher away from the stove that distance. It may not look nice, but before I find a thermal insulation board - it must be so (unfortunately such boards are unavailable in Dęblin !!!!). First wash tomorrow.
  • #15 6768091
    tonk07
    Help: 21
    Rate: 58
    Well 4.5 cm, and without a plate, it will be fine, unless you warm up the oven in the morning and then bread, cakes and baking cold meats until the evening :D
    kisses
  • #16 6768953
    Szczepaniii
    Rate: 26
    No exaggeration, recently I have been bucking around the stores and I was curious to watch these are plates from 1.5 cm thick and above, there is no point in pushing too thick, only the price of the thinner ones is about PLN 75 / piece.
    Regards
  • #17 6926488
    Piotr G.
    I glued a 1 cm thick hard polystyrene plate to the side wall of a gas cooker with an oven. The dishwasher is adjacent to this polystyrene. And everything is ok :) I would like to point out that it is an old "EWA" type gas stove and it heats up quite strongly when the oven works - and it does nothing to polystyrene, and most importantly, it effectively insulates both devices thermally.
    A cheap and effective solution - I recommend it :)
The discussion revolves around the safety and practicality of placing a dishwasher adjacent to a gas stove in a small kitchen. Users express concerns about heat transfer and potential damage to the dishwasher due to high temperatures from the stove. Recommendations include maintaining a minimum distance of 5-10 cm between the appliances, using non-flammable insulation boards if closer placement is necessary, and monitoring the temperature of the adjacent wall during oven use. Some users report successful experiences with their appliances in close proximity without insulation, while others emphasize the importance of proper insulation materials to prevent overheating. The conversation also highlights the need for careful consideration of the specific stove model and its insulation capabilities.
