Connecting Pioneer Subwoofer TS-WX206A: Power Cord & Leads Guide for Proper Setup
listek_ 24541 2
  • #1 6773665
    listek_
    Help: 11
    Rate: 34
    I have a pioneer TS-WX206A subwoofer. I need to plug it in, but I don't have a power cord :( Can anyone help me and write out the leads on the power socket? I will be very grateful.
    best regards
  • #2 6775434
    subaru555
    Rate: 23
    It appears to be an active sub. If you don't have a wiring diagram, you can definitely remove the case and trace which cables are going. And more precisely, which cube cables go to power the amplifier. From what I can see, it is probably enough to power, and the signal can be chinch.
  • #3 6777277
    listek_
    Help: 11
    Rate: 34
    Actually, I expressed it vaguely ... I have such a cable to be soldered to someone and I do not have the opportunity to rummage in the middle of the subwoofer. That is why I asked to write down the conclusions :(
    If anyone was interested then:
    1- nc
    2- "-"
    3- "+"
    4- ignition switch
    5- "-"
    6- "+"
    Regards and I close
