How to connect a passive subwoofer - how to connect a passive subwoofer to the r
jabbamuzik 22179 10
Can I connect the pictured passive subwoofer to a Pioneer VSX-D710S receiver, and how should it be wired?
The pictured Magnat unit is not a real subwoofer; it is a normal three-way speaker, so connect it like any other speaker/column to the receiver’s speaker outputs [#16330723] If you really want a subwoofer for this receiver, an active subwoofer with its own amplifier is the better choice [#16331289] A passive “subwoofer” like this is typically wired through an amplifier’s input/output terminals, with satellites on the output side, and in some sets it will not play unless the satellites are connected because the circuit stays open [#16331289][#16621472]
  • #1 16329011
    jabbamuzik
    I am new to the forum and ask for the advice of professionals, I searched the forum and somehow did not find the answer to my problem, I have a problem with connecting a passive subwoofer to the Pioneer VSX-D710S receiver, whether it is possible to connect such a subwoofer to this equipment or needs to be different, I send photos Subwoofer and receiver: How to connect a passive subwoofer - how to connect a passive subwoofer to the r How to connect a passive subwoofer - how to connect a passive subwoofer to the r
    Thank you all for your reply and help!
  • #2 16329038
    leonov
    Help: 1039
    Rate: 2251
    Is this "subwoofer" on the first photo?
  • #3 16329044
    jabbamuzik
    Yes, the first Magnat photo subwoofer, the second photo amplifier, I will add that two columns are connected to the Altus 75 receiver and I wanted to add a subwoofer
  • #4 16329078
    mariuszp19
    Help: 311
    Rate: 410
    In my life I have not seen a subwoofer with a frequency range of 26 - 25,000 Hz.
  • #5 16330723
    leonov
    Help: 1039
    Rate: 2251
    I have to worry you, this is not a subwoofer, it's a normal three-way speaker ;-) , connect it like any column :-)
  • #6 16330986
    jabbamuzik
    Thank you all for your reply! so I was made into a balloon with this subwoofer :( and which subwoofer do you recommend for this equipment?
    Ps: this is how the speaker looks inside
    • How to connect a passive subwoofer - how to connect a passive subwoofer to the r PHOTO_20170308_110208.jpg (4.86 MB) You must be logged in to download this attachment.
  • #7 16331289
    agraba
    Help: 43
    Rate: 47
    This is a passive subwoofer. It is connected to the amplifier (instead of speakers) where the input is written. Speakers (satellites) are connected where written output. This is a weakness. It is better to invest in an active subwoofer (with its own amplifier).
  • #8 16331367
    jabbamuzik
    Thank you for your answer !
  • #9 16621472
    pioryter
    I'll connect to the thread.
    I bought a similar 2 + 1 Magnat Tristar II set cheaply
    The so-called. "subwoofer" will play after connecting the satellites.
    If the satellites are not connected then this "subwoofer" does not play.
    So, as Leonov writes, it's really a two-way / three-way speaker.
    Without satellites the circuit is open and the speaker is "dead".
    If I would like to use this speaker as a subwoofer without satellites in a receiver with a separate subwoofer output, I should probably bridge the outputs on it.
    And now the questions:
    1. Is the bridge enough or give a resistor, e.g. 8 ohms, how do satellites have? If so ordinary is enough?
    2. Can I bridge the input / in of this speaker (the output to the subwoofer on the receiver is one and the input speaker has two Left and Right). The loudspeaker in this equipment is two-sound.
    I will advise you regarding the quality of the equipment:
    The receiver is connected to a computer via a digital input and is mainly about surround sound in games.
    Central and fronts are already playing, now I wanted to use this set as a subwoofer and satellites to the rear.
    2017-08-16
    Made without modifications.
    It was enough to remove the back wall and see how it can be connected without satellites.
    The game is fun - you can close.
  • #10 16647524
    jabbamuzik
    Subject to close, I changed the suba :)
  • #11 16654937
    pioryter
    It is a pity because this one also sounds good for the price :)
The discussion revolves around connecting a passive subwoofer to a Pioneer VSX-D710S receiver. The original poster mistakenly identified their Magnat speaker as a subwoofer, which was clarified by other users who noted it is a three-way speaker. They advised that the speaker should be connected like any standard speaker, and suggested investing in an active subwoofer for better performance. Further inquiries about bridging connections and using the speaker without satellites were raised, but ultimately, the original poster decided to change their subwoofer setup.
