Connecting Active Subwoofer (GJ5A 66960) from Mazda 6 to RCA Cable: Pioneer 2Din Station
infi 57066 9
How can I connect the Pioneer 2DIN head unit’s RCA subwoofer output to the Mazda 6 active spare-wheel subwoofer, which has only LP/ground/power wires and no RCA input?
Connect the Pioneer’s RCA line-level output to the subwoofer’s low-level input, not to speaker-level output, because the sub has a built-in amplifier and needs RCA-level signal [#15553770][#15553867] If the sub only has loose LP/ground/power wires, add an RCA socket or adapter cable and wire the RCA signal to the input and the RCA shield/negative to the common ground [#15553957] Use both left and right RCA channels from the radio if possible, because the sub can sum bass from both channels into one output [#15554409] It can still play from one channel, but two channels are better [#15554409]
  • #1 15553377
    infi
    Rate: 18
    I would like to ask for help in the correct and best connection of the active subwoofer from Mazda 6 (subwoofer that fits in the spare wheel)
    model GJ5A 66960
    From the pioneer 2Din station I have a 2-channel RCA HI for a subwoofer and I would like to connect it to this active subwoofer, the only problem is that there is no RCA input in it, and there is only a LP cable connection, ground, power supply.
    While there are converters from the Hi-LO cable connection to RCA, nowhere can I find a converter that would convert this RCA from the radio to a cable connection to the subwoofer>
    maybe it would be best to add some extra to the rca socket sub (just how to solder them)
  • #2 15553484
    piotrek22101
    Help: 695
    Rate: 1421
    The description shows that you have 4 wires in the sub
    As far as I know, these were powered from the amplifier and 6-wire from RCA.
    The change was from one year old.
    if there is L, R, only the mass of its wires can be common with the ground of the power supply, it would have to be checked.
    Make sure that the plus and minus are the power to the amplifier and therefore
    is it in the housing.
  • #3 15553770
    infi
    Rate: 18
    yes, the amplifier is in the sub because it is an active model with a built-in amplifier.
    the wire is 5.
    it looks like. (spreads out from another forum)
    Connecting Active Subwoofer (GJ5A 66960) from Mazda 6 to RCA Cable: Pioneer 2Din Station Connecting Active Subwoofer (GJ5A 66960) from Mazda 6 to RCA Cable: Pioneer 2Din Station
  • #4 15553867
    piotrek22101
    Help: 695
    Rate: 1421
    If there is an input for an amp, the signal from RCA is needed. Speaker too strong.
  • #5 15553950
    infi
    Rate: 18
    i.e. :) ? Well, I send the sound signal to the sub via RCA cable from the radio and this cable I want to connect somehow to this sub from Mazda.
    what are you talking about with the speaker too strong?
  • #6 15553957
    piotrek22101
    Help: 695
    Rate: 1421
    As with rca you want to give it ok. Some give straight from the speakers and then you are surprised that it sounds bad.
    Pros from L / R to Rca Pros and Rca Minuses
    to one of the others. You have to find a diagram.
  • #7 15554020
    infi
    Rate: 18
    and which means to which of the others :) ?
  • #8 15554032
    piotrek22101
    Help: 695
    Rate: 1421
    I'm looking for a description. Only from what I remember, the Mazda signal is something different, similar to rca, but it is different. A friend from Aso Mazda has gone on vacation, he will send me the diagrams after Christmas. Right now I'm looking for it on the net.
  • #9 15554299
    infi
    Rate: 18
    as in the pw, in the game, here too, because it is mainly about the issue of making additional RCA sockets in this subject, I do not know if it can be done like this
    SPELLING!!!
    3.1.13. Take care of linguistic correctness, follow the rules of netiquette. Don't post messages that are difficult to read and understand what the other party really meant.
    piotrek22101
    Help: 695
    Rate: 1421
    It will also play on one of them. It is best if there are two from the radio, because then it takes the bass from both channels, sums it up and gives it to one.
The discussion revolves around connecting a Mazda 6 active subwoofer (model GJ5A 66960) to a Pioneer 2Din station using RCA cables. The subwoofer lacks RCA inputs, featuring only LP cable connections, ground, and power supply. Users suggest that the subwoofer's amplifier requires a signal from the RCA output of the radio. There are inquiries about the possibility of creating additional RCA sockets for the subwoofer and the need for proper wiring to ensure sound quality. Some participants mention the importance of using the correct wiring configuration to avoid poor sound performance.
