Repairing Broken Veneer: Fixing Screw Damage, Smoothing Burr, and Preventing Cloth Snags
moddyy 37835 6
  • #1 6795907
    moddyy
    Help: 13
    Rate: 17
    When assembling the furniture, one screw went a little too far and a little bit pushed out, on the other hand, the bulge is small, but the veneer continuity has been broken and a small burr has formed which I have to remove somehow and I don't know too much about it, so that when cleaning the cloth afterwards, nothing will get caught on the cloth. can you smooth it properly?
  • #2 6795965
  • #3 6796049
  • #4 6796637
    scorpionn17
    Rate: 10
    put a little glue (some carpentry veneer or something similar), press it and if there is any gap, buy wood putty (there are different colors) and putty.
  • #5 6796719
    MoniTOX
    Help: 80
    Rate: 322
    It is best to smooth and stick a piece of new veneer under the color.
    Veneers are available in some stores, e.g. obi etc.
  • #6 6797230
    niutat
    Level 36  
    Help: 288
    Rate: 760
    If the board is pushed out, it will be difficult to mask it aesthetically, maybe think about a cover for a screw, it is always better than a piece of veneer that you will not fit perfectly anyway.
  • Flatten veneer bulge and fill damage with glue
    #7 6797326
    Błażej
    Help: 1923
    Rate: 3627
    It's on the front, on the side?
    You can't fix any bumps or a cracked plate. You can possibly stick this bulge as low as possible and then harden the place with some varnish. and fill the hole from the inside with some glue, the teeth caught the broken chips.
    If this is a poorly visible place, then either some kind of plug, sticker, or a furniture fastener made of two screws with large flat heads (one screwed into the other).
The discussion focuses on repairing a broken veneer caused by a screw that was over-tightened, resulting in a small bulge and burr. Suggested solutions include sanding the area and applying a clear coat, using a hot iron to flatten the bulge, applying glue and wood putty to fill gaps, or replacing the damaged veneer with a new piece. For aesthetic concerns, alternatives like using a screw cover or furniture fasteners are recommended, especially if the damage is in a less visible area. The importance of using appropriate materials and techniques to ensure a smooth finish and prevent snagging on cloth is emphasized.
