Bosch - no instructions and I don't know how to set the clock
jotem52 23592 6
  • #1 16704393
    jotem52
    I bought an apartment with a Bosch stove, but the previous owner lost the instructions. There is no tag anywhere on the stove model. Maybe some of you will recognize it and help you set the clock.
    MDD
    Help: 179
    Rate: 545
    Try to hold the 1st and 2nd buttons from the left simultaneously. Then + or -.
  • #3 16704441
    yanes
    Help: 210
    Rate: 609
    You tried the standard combination, you press the bell button and the second button next to it, you choose the time with the plus and minus.
  • #4 16704449
    sanfran
    Help: 963
    Rate: 3004
    If you have a problem with the setting, turn on the power at the time when the clock is set by default (12:00 or 00:00).
  • #5 16704469
    jotem52
    Aligned, thanks. And how to disable the alarm permanently? One day he woke us up at night and I had to unplug the stove because I couldn't stop it!
    MDD
    Help: 179
    Rate: 545
    There is probably no such possibility. If you don't set the alarm, it shouldn't work. With koro you turned off the power, the programmer should reset. It is possible that someone accidentally started the timer. Download the manual, e.g. amika G6E3SZTc can fit. Here you have +, - there is a knob.
  • #7 16704776
    jotem52
    Thank you, it finally works!
The discussion revolves around setting the clock on a Bosch stove after the user lost the instructions. Several users provided solutions, suggesting combinations of button presses to adjust the time. One method involves holding the first and second buttons from the left while using the + or - buttons to set the time. Another user mentioned pressing the bell button along with the second button to select the time. Additionally, there was a query about disabling an alarm that had activated unexpectedly, with advice given that if the alarm is not set, it should not function. A suggestion was made to download a manual for a similar model, Amika G6E3SZTc, which may provide further guidance.
