Setting Amica 51GE332ZPTAR (W) Cooker Clock: Adjusting Time after Disconnecting Power
wojtalov 233662 3
  • #1 6509517
    wojtalov
    Rate: 32
    I warmly welcome!
    I have a little problem with setting the clock on an AMICA cooker. The problem is that, even after disconnecting from the power, it is an hour stays as she was!
    And here the question arises: How to correctly set the time in this cooker, because the manual only says "after turning on the power, the time should be 0:00 or 12:00" ??
    For help, I will add two photos showing the stove in its entirety and the control panel:
    Thanks for any help !!
  • #2 6509604
    gruby1
    Help: 126
    Rate: 171
    When you disconnect from the power, you should wait for a while (mine lasts for about 5 minutes). I might be wrong because I'm not home, but try pressing both arrows at once.
    Mistake. You have to hold the middle button for a long time.
  • #4 6510555
    wojtalov
    Rate: 32
    Thank you to all of you, especially the box moderator!
