PC won't start – black screen, 3 beeps, what to check?
goralka3 30875 5
  • #1 6907634
    goralka3
    Rate: 28
    My friend has a problem with the comp. Well, the comp does not give an image to the monitor - the monitor is black as if it was turned off. When turning on the computer squeaks three times. The disk diode lights up once and sometimes not. What could be the problem? How to get it to work? It does not respond to ctrl+Alt+Del and to nothing else.
    Very please give me some helpful advice.
  • #2 6907753
    morus12
    Compare the beeping to the table Beep Codes ; depending on the type of BIOS and code, you will find out what the cause is.
    Check if the beeping is three times short or if there is any difference between the length of the sound - this is important.
  • #3 6907767
    zbyszek_2013
    Rate: 10
    The beeping message depends on the BIOS of the computer. Without delving further: if it is 1 long squeak and 2 short squeaks it is a graphics card error signal, if 3 short squeaks RAM error.
  • #4 6907808
    swsebastian
    Rate: 13
    Try pressing down on the RAM bones!
  • #5 6908187
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    There may be as many reasons as there are users on this forum. We need a complete computer configuration at the beginning so that we don't have to guess what our friend has there. Have your friend try to disconnect all unnecessary devices (such as disk, CD/DVD drive) and leave only the set: Motherboard + processor + RAM + power supply and then try to start the computer.
  • #6 7505630
    goralka3
    Rate: 28
    The cause was RAM memory, unfortunately replacing it helped.
    Thank you all for your help :)
    Regards!
