Continuous BIOS Beeps and Windows Starting Loop During Computer Boot-Up
xDominocPvP1337 6171 15
Why does my PC loop on the Windows starting screen and then emit two BIOS beeps repeatedly during boot?
This usually points to a hardware fault, often RAM, rather than Windows itself; check which BIOS you have because the meaning of 2 beeps depends on the BIOS, and on many AMI boards it indicates memory trouble [#16646630][#16646639] Remove one RAM stick and try booting, swap the sticks, reset CMOS after each change, and run Memtest86+ to check the memory [#16646639] If the machine reaches “Starting Windows” and then resets again, it looks like a serious system error/hardware problem [#16646634] Also check the disk with MHDD/SMART and try booting a Linux USB; if Linux boots, the problem is more likely the Windows installation or the drive [#16646645][#16646668]
  • #1 16646601
    xDominocPvP1337
    Rate: 12
    The computer turns on the inscription is starting windows, then the bios beeps 2 times and so over and over again
  • #2 16646602
    Kasek21
    Help: 4981
    Rate: 3547
    Full computer configuration including the make and model of the power supply ?!
    Bluescreen appears?
  • #3 16646617
    xDominocPvP1337
    Rate: 12
    Intel xeon 4x2.50ghz. 4GB ram 250 GB win disk 7 pro 64 bit. Acer veriton radeon hd card. Motherboard pegatron Ipm 31 hipro 250 vat power supply
  • #4 16646618
    Kaliber PC - Service
    Help: 50
    Rate: 69
    In addition to the configuration let it Author will let you know if any OC was taken, hardware replacement along the way, maybe uploading new drivers, updating the BIOS ...
    Added after 56 [seconds]:
    Problems arose suddenly or after any of the activities listed by me (or other)?
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
  • #5 16646624
    karolark
    Help: 702
    Rate: 2516
    By emergency?
  • #6 16646625
    xDominocPvP1337
    Rate: 12
    The kiddy arrived, the courier was broken, the power on button was repaired, I started it and it happened
    karolark wrote:
    By emergency?
    by f8 it's not
  • #7 16646630
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    You have a model of this desktop described as
    Acer Veriton P130 (Intel Xeon + NVIDIA Quadro) link
    See what Bios you have (you should enter) and then by the manufacturer (AMI, AWARD) you will recognize what 2x beep means
    As far as I remember there was AMI.
    Here you can see the name of the disc link
  • Suspected serious system error after power button repair
    #8 16646634
    Help: 50
    Rate: 69
    So it goes so that it comes to the moment of "Starting in progress ...", the BIOS beeps twice, the computer resets and the whole process goes all over again and so near Maciej? If so, it looks like something serious system error.
    KiEdy arrived, the courier was broken, the power on button was repaired, I started it and it happened
    So the computer is new ?
  • #10 16646642
    xDominocPvP1337
    Rate: 12
    The computer is not new and I will add that he turned on the desktop twice and played normally
  • #11 16646645
    safbot1st
    Help: 2719
    Rate: 1585
    Probably "hardware".
    Provide SMART Disk with bootable MHDD.
    Check if bootable linux works with pena. If yes = damaged soft / disk.
  • Suggesting SMART and Linux boot tests for diagnosis
    #12 16646646
    xDominocPvP1337
    Rate: 12
    and how to do it because I'm green
    Added after 8 [minutes]:
    And when I turn on the computer, something with repairs option pops up (recommended) and start the system normally, including repair hangs
  • #14 16646697
    xDominocPvP1337
    Rate: 12
    I'm on this page but what to download
  • #15 16646759
    karter
    Level 19  
    Help: 33
    Rate: 53
    Right click on the link, then copy, then paste it into the top search bar.
  • #16 16654187
    xDominocPvP1337
    Rate: 12
    Subject you can close your computer went under warranty
The discussion revolves around a computer boot issue characterized by continuous BIOS beeps and a Windows starting loop. The user describes a system with an Intel Xeon processor, 4GB RAM, and an Acer Veriton desktop. Responses suggest checking the BIOS beep codes, which may indicate hardware issues, particularly with RAM. Recommendations include reseating or swapping RAM modules, performing a CMOS reset, and using diagnostic tools like MHDD to check the hard drive's health. The user also mentions encountering a repair option during boot, indicating potential software or disk damage. The conversation concludes with the user noting that the computer is under warranty.
TL;DR: 2 BIOS beeps during boot usually point to RAM faults; "Take out one bone and try." Swap sticks, reset CMOS, run Memtest86+, or check the disk with UBCD/MHDD. [Elektroda, safbot1st, post #16646639]
Why it matters: This FAQ helps DIY PC users quickly stop a Windows boot loop with BIOS beeps and isolate faulty RAM or storage.
What do two BIOS beeps mean when Windows says "Starting Windows"?
Two short beeps typically indicate a memory error on AMI-based systems. Reseat the RAM, try one stick at a time, and reset CMOS between changes to clear training issues. If it still loops, proceed to memory testing and disk SMART checks before blaming Windows. [Elektroda, safbot1st, post #16646639]
How do I stop the boot loop with two beeps on my desktop?
Start with RAM. Power off, remove one stick, and boot with the other. Swap slots and sticks. After each change, reset CMOS via the jumper. Then run Memtest86+ from USB. If RAM passes, check disk SMART with MHDD from UBCD. [Elektroda, safbot1st, post #16646639]
How do I run Memtest86+ from a USB stick?
  1. Download the Memtest86+ USB installer referenced in the thread and create a bootable USB.
  2. Boot from USB and let Memtest86+ run at least one full pass.
  3. Replace any module that throws errors; test each stick individually to confirm. [Elektroda, safbot1st, post #16646639]
How can I check my hard drive’s SMART without booting Windows?
Create a UBCD boot USB, start the PC from it, and launch MHDD. Select your drive and read SMART (F8). If you see reallocated or pending sectors, back up and replace the drive. This isolates disk faults before OS loads. [Elektroda, Kasek21, post #16646668]
Is this a software or hardware problem?
The thread’s triage points to hardware. As one expert put it, "Probably 'hardware'." RAM faults or a failing disk can trigger beeps and loops before Windows fully loads. Confirm with Memtest86+ and MHDD before attempting OS repairs. [Elektroda, safbot1st, post #16646645]
Startup Repair hangs—what does that tell me?
If Windows’ automatic repair stalls, suspect underlying hardware. In the thread, Startup Repair hung repeatedly, strengthening the case for RAM or disk issues instead of pure software corruption. Test memory and check disk health next. [Elektroda, xDominocPvP1337, post #16646646]
Which BIOS is on Acer Veriton, and how do I match beep codes?
The helper advised checking BIOS vendor in Setup; Acer Veriton models here were associated with AMI. Once confirmed, use AMI’s two-beep mapping to focus on RAM. This avoids chasing unrelated causes. [Elektroda, lisek, post #16646630]
What configuration was the problem PC using?
Intel Xeon 4×2.50 GHz, 4 GB RAM, 250 GB drive, Windows 7 Pro 64‑bit, Acer Veriton with Pegatron IPM31 board, Radeon HD GPU, and HIPRO 250 W PSU. These specs help target RAM and PSU checks first. [Elektroda, xDominocPvP1337, post #16646617]
Could shipping damage cause the symptoms?
Yes. The unit arrived with a broken power button. Physical stress can loosen modules or damage traces, leading to intermittent POST beeps and boot loops. Document damage, reseat components, and pursue warranty if issues persist. [Elektroda, xDominocPvP1337, post #16646625]
What should I do if a live Linux USB boots fine?
If a live Linux session runs stably, your hardware is likely OK, and the Windows install or drive filesystem may be the issue. Back up data and consider a clean reinstall after checking SMART. [Elektroda, safbot1st, post #16646645]
What is MHDD?
MHDD is a low-level disk diagnostic that reads SMART and scans for slow or bad sectors outside Windows. Run it from UBCD to avoid OS interference and to assess drive health before reinstalling. [Elektroda, safbot1st, post #16646645]
What is Memtest86+?
Memtest86+ is a bootable memory testing utility. It stresses RAM outside the OS to reveal errors. “Take out one bone and try” pairs with Memtest to isolate a bad module or slot with confidence. [Elektroda, safbot1st, post #16646639]
What is a CMOS reset and when should I do it?
A CMOS reset clears stored BIOS settings. Use the motherboard jumper after each RAM change to retrain memory settings and eliminate corrupted NVRAM as a cause of repeated beeps. [Elektroda, safbot1st, post #16646639]
What ultimately fixed the issue in this thread?
The owner ended the thread after sending the PC under warranty. RMA was the final route once basic RAM and disk checks were advised and symptoms persisted. [Elektroda, xDominocPvP1337, post #16654187]
