Adding Multiple Conditions to an Excel VBA IF Statement for Cells F6, H6
karolczyzycki 16368 5
  • #1 7018505
    karolczyzycki
    Rate: 43
    How in such an IF loop, add a few more conditions?
    At this point, error is shown if cell F6 is empty.
    How do I add a few more cells to this condition?
    my code:
    If (Range("F6") = "") Then
    Range("N6") = "Błąd"
    Else
    end if
    This doesn't work:
    If (Range("F6,H6") = "") Then
    nor this:
    If (Range("F6" & "H6") = "") Then
    If it adds cells after the decimal point, it only satisfies the first condition, if I type "&" I get an error.
    What should I type in to make this work as a product of terms?
  • #2 7018610
    Czybyszew
    Help: 37
    Rate: 137
    If (Range("F6") = "") and (Range("H6") = "") and (Range("J6") = "") Then .....
  • #3 7018651
    karolczyzycki
    Rate: 43
    This code also throws an error:
    Run-time error '13':
    Type mismatch
  • #4 7018706
    Czybyszew
    Help: 37
    Rate: 137
    It may be so
    If Range("F6") = "" and Range("H6") = "" and Range("J6") = "" Then .....
    and if not that
    If (Range("F6") = "" and Range("H6") = "" and Range("J6") = "" ) Then .....
    I haven't used VB for a long time, but in Pascal-type languages, conditions are joined by "and" and "or", etc.
  • #5 7019010
    Dżyszla
    Help: 1095
    Rate: 226
    AND na - just F1 in the editor ;)
  • #6 7070472
    walek33
    Help: 132
    Rate: 81
    In the file you have an example of use If, And in VBA (cell B2) and similar use of formulas If, And Excel (cell B3).
    • funkcja.xls (20 KB) You must be logged in to download this attachment.
