Excel: Using IF Formulas for Matching Partial Text, Counting Names, and Filtering Values
wolnyjac21 22728 16
How can I use Excel formulas to match partial text, count matching names in a range, and return only rows where another column equals 1?
Excel does not treat `=IF(B26="*",...)` as a wildcard test there, because that comparison checks for a literal asterisk; for prefix matching you need a text function such as `COUNTIF` with `*`, or a `FIND`/`LEFT`-based test, and `FIND` is case-sensitive [#13614361][#13615756] To count how many cells in `B1:B50` contain a given name in one cell, use `COUNTIF` over the whole range instead of dragging an `IF` down the column [#13615756] For values starting with `K` in column G, use `COUNTIF` with a pattern like `K*`; that approach does not distinguish uppercase and lowercase letters unless you use a different formula [#13616062] For the last case, the thread suggests using an auxiliary/helper column, for example with `ROW()`, and then working from that column rather than trying to do everything directly in one formula [#13615756]
  • #1 13613906
    wolnyjac21
    My question, why are none of the following formulas true?
    = IF (B26 = "*", 1,0)
    = IF ((B26 = "k *"), 1,0)
    = IF ((B26 = "k" & "*"), 1,0)
    b26 contains the word: smith
    And, in fact, I have one more question.
    In the column from B1 to B50, for example, I have different names and now I do this:
    = If (b1 = "smith", 1,0) - I drag down
    and I am counting up how many of them is the count if function
    My question is: how to do this in one cell?
    And maybe the last one:
    We have a column with the values 0.1
    example
    lp | b
    1 | 0
    2 | 0
    3 | 1
    and now I would like to enter only those lp for which their value is 1 in column C.
    I know that you can use a filter, but I would like to know if there is also a regulation.
  • #2 13614194
    JRV
    VBA, Excel specialist
    Help: 805
    Rate: 455
    Welcome
    1. = IF (FIND ("k", B26) = 1, 1, 0)
    2. = SUM IF (B1: B50, "blacksmith")
  • #3 13614311
    wolnyjac21
    1. The find () function will return 7, so your example returns nothing but false and this solution is not suitable for me.
    I would like to check if there is a string with some letter at the beginning and I wonder why the "*" which means any string does not work for me?
    2. This example is also incorrect, or at least it does not meet my requirements
    JRV
    Help: 805
    Rate: 455
    1. The find () function is case sensitive.
    2. Sorry - COUNTIF
    ps Among others, the COUNTIF function allows the characters *
  • #5 13615524
    cbrman
    Help: 177
    Rate: 61
    freejac21 my glass ball prompts you to attach a file with sample data.
    marek003
    Level 40  
    Help: 801
    Rate: 488
    It doesn't work for you because excel is mostly made for math and numbers. Excel has completely different functions for operations on characters.
    The condition you applied to the function if is a simple comparison of the value in cell B26 and a string. In your case, a single "asterisk" string. In this case, excel (as well as other spreadsheets) checks whether cell B26 has not entered * (and not anything) because "whatever" is, for example, a function or empty ().
    As for the first one, it is enough to redo what your friend suggested JRV
    = IF (COUNTIF (B26, "k *") = 0; 0; 1)
    Only here (what he mentioned JRV ) there is no case-checking, that is
    this formula will give the same result:
    = IF (COUNTIF (B26, "K *") = 0, 0, 1)
    As for the second (again for a colleague JRV )
    = COUNTIF (B1: B50, "blacksmith")
    And as for the third - it's not that simple.
    Maybe a support column?
    Because if so, you can ultimately use e.g. max k () and in the auxiliary column put ROW ().
    Or if "1" can be replaced immediately with the line number [ROW ()], it is enough in the third column max.k () and that's it
  • #7 13615973
    wolnyjac21
    Thank you very much for all the answers :)
    Now it remains to fight the sheet, maybe something will work ^^
    and such a question, what mistake am I making here:
    = COUNTIF (G59: G263, IF (LEFT (G59,1) = "k", 1,0))
    ehh somehow, I can't compile the data into one column .. I always have to use 10 helpers; \
  • #8 13616062
    Maciej Gonet
    Help: 824
    Rate: 481
    Good morning,
    If there are names in column G, and we want to determine how many of them start with "K", then we should use the formula:
    except that this formula does not distinguish between uppercase and lowercase letters. If it were important you would have to use a different formula.
    Regards.
  • #9 13616154
    wolnyjac21
    How to sum float numbers, i.e. a floating point number because Sum () returns 0; /
  • #10 13616238
    marek003
    Level 40  
    Help: 801
    Rate: 488
    = COUNTIF (G59: G263 , IF (LEFT (G59,1) = "k", 1,0) )
    First
    "," it is not ";"
    and are you sure this is the counting condition you mean ?:
    As for floating point, format the summed and result cells to floating point and it should be ok. Because in my opinion the sum works, but you don't see the "whole" result.
    Cell format - custom and select e.g. "0.00E + 00"
  • #11 13616259
    cbrman
    Help: 177
    Rate: 61
    You can use the following table formula to add up the number of surnames beginning with "K"
  • #12 13616289
    wolnyjac21
    First
    "," it is not ";"
    As for floating point, format the sum and result cells to floating point and it should be ok. Because in my opinion the sum works, but you don't see the "whole" result.
    Well, unfortunately, the excel I'm playing requires commas, not semicolons ... but it's not that important.
    Secondly :) the cells are formatted and the sum is 00.00 I don't know, maybe this excel is bugged ..
    Anyway, thanks a lot for your help ^^
  • #13 13616317
    marek003
    Level 40  
    Help: 801
    Rate: 488
    And what excel is this - version and for which country - UK?
    As for the sum, it is impossible
    0.05 + 0.05 will get you 0.1
    What do you type in the cells?
    And when you press the "increase decimal" button - such an arrow to the left with zeros - nothing happens?
    And thirdly, as you can see "00.00", you have an ordinary - number format
    In the case that I showed you, if it was 0 (zero) he could see not 00.00 but "0.00E + 00"
    for example, with 0.000000000005 you would see "5.00E-12" and with "your" format you just see "00.00" with such a small number
  • #14 13616733
    wolnyjac21
    Version 2007. As for the country, to be honest, I don't even know, because I installed excel only for a moment (to remind you of certain things) and on Linux.
    Unfortunately, I will not answer you any more questions, because I got rid of excel :)
    Anyway, thank you for your interest in the subject and I hope your advice will not go to the woods ^^
  • #15 17672436
    katharinaa
    Hello, in column G I have five-digit codes, I want to count those starting with the number 2.
    = IF (COUNTIF (G2: G31; "2 *") = 0; 0; 1)
  • #16 17672472
    Maciej Gonet
    Help: 824
    Rate: 481
    If these codes are texts then:
    If they are numbers then:
    [syntax=text]=LICZ.WARUNKI(A6:A12;">=20000";A6:A12;"
    • kody5cyfr.xlsx (9.08 KB) You must be logged in to download this attachment.
  • #17 17672683
    katharinaa
The discussion revolves around the use of IF formulas in Excel for matching partial text, counting occurrences of names, and filtering values. The user initially inquires why certain formulas using wildcards do not return true when checking for partial matches in cell B26, which contains the word "smith." Responses suggest using the FIND function and COUNTIF for partial text matching, emphasizing that Excel's IF function performs simple comparisons rather than pattern matching. The user also seeks a method to count names in a range (B1:B50) in a single cell, with suggestions to use COUNTIF. Additionally, the user asks how to filter values based on a condition (e.g., displaying only rows where a corresponding value is 1), with recommendations for auxiliary columns and specific formulas. The conversation touches on case sensitivity in functions and formatting issues with floating-point numbers.
