Excel VBA: Find Specific Value in Column and Perform an Action after Condition Met
gr3krk 14850 3
  • #1 16246590
    gr3krk
    I am asking you for help because I can not deal with it. I am aware that this is nonsense but still ... :)
    I need a VBA code that checks if there is a specific value in the given column, for example "1" and if it does something like doing it (eg opening a different file and copying the indicated values - I have done and works ... I just need to condition) and if not it goes on to the next part.
    Thanks in advance for your help.
    Greetings.
  • #2 16246737
    adamas_nt
    Help: 1508
    Rate: 659
    And the If-Then-Else statement does not work?
    kinggustav
    Help: 93
    Rate: 93
    Maybe try searching through "CtrlF"? In VBA it will be like this:
    Dim r1 as Range
    Set r1 = Range ("C1", Range ("C1"). End (xlDown)). Find ("Search")
    If r1 Is Nothing Then 'not found
  • #4 16249023
    gr3krk
    Thanks for the answers!
    kinggustav, works :) ) Thanks again.
