[java] Setting Size for Dynamic Array in Main Method: User-defined String Name[] Array Size
przemo_wielki 29988 6
  • #1 7232730
    przemo_wielki
    Help: 61
    Rate: 10
    I have a problem with setting the size for a dynamic array, it's best to give an example:
    public class Osoba {
    String imie[]; //dynamiczna tablica
    public class Przyklad{
     public static void main(String[] args){
      int rozmiar=5;
      Osoba nowy[] = new Osoba();//dynamiczna tablica obiektow
    Question: how to set the size of the String name [] in the main method? I would like the user, while the program is running, to choose how many names (eg) can be assigned to a person (the size of the dynamic array Name []).
    ps: I'm a beginner, so please be understanding;]
  • #2 7233418
    Dżyszla
    Help: 1095
    Rate: 226
    or by any chance:
    Osoba []osoby=new Osoba()[rozmiar]
    But I do not give my head - there is not enough to do with Java.
  • #3 7233593
    mrio
    [code:1:9457c0dc6f]
    rozmiar = 10;
    Osoba[] osoby = new Osoba[rozmiar];
    for (int i=0; i
  • #4 7233758
    przemo_wielki
    Help: 61
    Rate: 10
    In the previous code a bug crept in (I wrote hard without a compiler) correct object creation should look like this:
                Osoba[] nowy;//dynamiczna tablica obiektow
                nowy = new Osoba[rozmiar];
    //lub  Osoba[] nowy = new Osoba[rozmiar];
    Only I know it exactly. I want to set the size for the object field new [] from the main () function; is it possible?
    I'm talking about :
    Dżyszla
    Help: 1095
    Rate: 226
    in a constructor or via a public variable.
    mrio
    public class Main {
        public static void main(String[] args) {
            int rozmiar = 5;
            osoby[0] = new Osoba(2);
            osoby[1] = new Osoba(1);
            // ... itd.
    class Osoba {
        String[] imiona;
        // Tworzy obiekt Osoba o podanej liczbie imion.
        Osoba(int liczbaImion){
            imiona = new String[liczbaImion];
  • #7 7234030
    przemo_wielki
    Help: 61
    Rate: 10
    Heh actually;] and I was combining miracles of wreaths :D
    The constructor did the trick.
The discussion revolves around setting the size of a dynamic array for a user-defined class `Osoba` in Java. The user seeks to allow dynamic input for the size of a `String` array within the `Osoba` class, specifically for storing names. Various responses suggest initializing the `Osoba` array with a specified size and using a constructor to define the size of the `String` array for names. The correct approach involves creating an `Osoba` array in the `main` method and utilizing a constructor to allocate the `String` array based on user-defined size.
