[C++] How to count letters in a first and last name?
Yerild 13749 6
  • #1 13536154
    Yerild
    Rate: 13
    Hello everyone. I need help in writing a program where I could enter a first and last name, and then the program would print out the number of letters of that first and last name. Unfortunately, I can't write it, I would like some not very complicated code.
  • #2 13536219
    D12
    Help: 8
    And what can't you do, read the name on the keyboard or count the letters?
  • #3 13536226
    Yerild
    Rate: 13
    Okay, I've managed it :)
    Here is the code (may be useful to someone)
    [code:1:621e19b84e]#include
    #include
    using namespace std;
    int main()
    string st;
    int dl;
    coutst;
    dl=st.length();
    cout
  • #5 21313583
    pseudocfoch
    Why in C++? You can do it in Python easier and fast. Unless you need to repeat this process millions of times, then you may consider C++.
  • #6 21315637
    JacekCz
    Help: 760
    Rate: 1464
    the_fifth_horseman wrote:
    Read the documentation:
    Seriously, you perceive the questioner @Yerild as someone who reads the documentation ?
    Added after 6 [hours] 3 [minutes]:
    Yerild wrote:
    cin>>st;
    dl=st.length();
    cout<< "The number of letters of your name'"<<st<<"' is"<<dlt<<endl;
    Jean-Marie ... does not display number of letters
  • Correcting the flawed char division approach
    #7 21689366
    Matx91
    In C on numbers I would do it like this:
    Depends on the number of letters. If there are, say, 5, then the first character is a variable divided by 1000. That's on numbers. And when it comes to the alphabet, it has 32 letters - you have to divide the number of digits by 32 and multiply by the letters it puts out. E.g. Matx, I want M then I make the variable digit=char/(32) and I have the first one and if I want the last one I guess digit=char/(32*4) because x is the fourth character,because there are four letters. And this is how I would solve it. Greetings. I think I am thinking correctly?
    Added after 5 [hours] 31 [minutes]: .
    In the C language, char is a basic data type used to store a single character that is represented by its numeric value, usually an ASCII code. Although char is single-byte, its default state can be signed (from -128 to 127) or unsigned (from 0 to 255), depending on compiler options or the char type. In the C language, char is also keyed to create strings, which are actually arrays terminated by a special NULL character (¯0), rather than string objects. So you divide by the maximum you can use in an ANCI character
    Divide by the maximum number that fits in one character and it should work
    Moderated By gulson:
    The advice is wrong. 3.1.11. Publish posts that do not contain substantive content, contain harmful advice, advice that does not attempt to solve a problem, and publish identical posts that follow or repeat information included in the course of the discussion.
The discussion is about a simple C++ program that reads a first and last name and prints the number of letters in the entered name. The suggested solution uses the C++ string type, stores the input in a string variable, and obtains the character count with the length() method. One response points to the C++ string documentation and mentions that there are multiple ways to solve the task. Another comment notes that the problem could be done more easily in Python, while a later reply incorrectly discusses counting letters using numeric division and char values.
