Pioneer Headphones: Identifying + and - Polarity on Wider and Narrower Inscriptions
fnk 70577 9
Which speaker terminal is positive and which is negative when the connectors are marked only by a wider and a narrower tab?
Usually the wider terminal is plus and the narrower terminal is minus [#713654] If you want to verify it, briefly connect a 1.5 V battery to the speaker: that is a simple polarity check for any speaker [#713805] You can also confirm the phase by listening with the balance/fader; if bass gets better after swapping one speaker’s wires, that speaker was wired out of phase [#713744] Sometimes a dot on the basket marks the start of the winding, which means plus [#714193]
  • #1 713602
    fnk
    My question is very banal, but unfortunately it causes a lot of trouble for me, so recently I bought pioneer phones on the exchange, as it turned out, after opening the pad, there are no instructions :( .
    Now there is a problem where to connect + and where -, so there are no markings on the speakers, only the inscriptions differ
    - one is wider
    - the second is narrower
    Help me please, which is a plus and which is a minus.
  • #2 713654
    Przemek82
    Rate: 20
    As a rule, it happens that:
    - wide connector +
    - narrow connector -
    However, if you connect them relying only on the wires from the radio or amplifier (i.e. plus from the radio to the wide connector, minus to the narrow or plus to the narrow and minus to the wide) it will be indifferent to the speakers, because they will still play in phase.
    Regards
  • #3 713669
    fnk
    if I connect the other way round, nothing will happen to the speakers?
    Besides, when I tried it, I noticed that after a narrow plus and a wide minus dish, all the time trembled, not only with the bass. So I decided that wide is a plus and I hope it will be good :)
  • #4 713682
    noody2051
    hmm, in general, nothing should happen to them
    one should only remember that the "natural" first movement of the speaker diaphragm along with the voice coil is forward and then backward
    therefore, with a strong impulse and reverse polarity, there is a possibility of mechanical damage to the coil by the magnet
  • #5 713719
    fnk
    I will say that my speakers are pioneer TS-A2065, maybe someone has the same and he has an instruction :( or for sure wide is a plus
  • #6 713744
    MARTIINO
    Help: 23
    Rate: 95
    You do not need any manual that you will never find in a Pioneer loudspeaker. It's just not there. You can check the phases on the speakers very easily. By setting the fader on the speakers you want to check and moving the balance to one side you can notice an increase or lowering the sound quality (bass). If after setting the balance on, for example, the right side of the speaker, if the speaker transfers bass better, it means that you have incorrectly polarized phases. At this point, just turn the cables in only one of the speakers and everything will be OK if you can hear a reduction in sound quality with balance regulation it means everything is OK and the phases are correct.
    I think I wrote it quite simply and understandably.
    Regards
  • #7 713805
    MICHAŁ
    Help: 15
    Rate: 30
    I check the polarity of the speakers (of any manufacturer) in the following way: I take a 1.5 V battery or other DC voltage source of such value and connect it to the loudspeaker. amplifier.
  • #8 714193
    Przemek82
    Rate: 20
    Hehe no fact, the easiest way, and I forgot about it :wink: . I might add that sometimes a dot is painted on the basket that signifies the beginning of the winding (i.e. plus).
    Regards
  • #9 7544747
    hsv
    I will refresh the topic a bit, because I also have a problem with the phases in the speakers. In the car (Audi A3 8L) I have the original Bose sound system. 4 speakers in the front, 2 in the rear and a horn in the trunk. I used the MARTIINO method, and it turned out to me that in the front the left speaker plays without bass (the tuba does not turn on), the right speaker plays with bass (tuba plays), while on the back the left speaker plays with bass (with tuba) and the right one without bass (without tuba) ). I don't know much how to interpret it. Please help.
  • #10 7547164
    qstosz
    Help: 186
    Rate: 249
    Maybe it must be great
    oBose system ;)
The discussion revolves around identifying the polarity of Pioneer headphones, specifically regarding the connection of wide and narrow connectors. Users suggest that typically, the wide connector is positive (+) and the narrow connector is negative (-). However, it is noted that connecting them in reverse will not damage the speakers, although it may affect sound quality. To verify polarity, users recommend checking the sound balance or using a 1.5V battery to observe the diaphragm movement. One participant mentions the Pioneer TS-A2065 model, seeking confirmation on the polarity markings. Overall, the consensus is that while polarity is important for optimal sound performance, incorrect connections will not cause permanent damage.
