How to connect and use an RTV antenna socket for TVP, TVN, Polsat channel reception
jikolp 41189 8
  • #1 7350835
    jikolp
    can someone tell me how to use such a socket How to connect and use an RTV antenna socket for TVP, TVN, Polsat channel reception
    Added after 4 [minutes]:
    I just mean a good reception of tvp tvn polsat channels
    Please read electrode regulations .
    I corrected the title. Regulations point 10.9 . [SP5ANJ]
  • #2 7350871
    zak12
    Help: 16
    Rate: 17
    Depends on what signal source you are using. What you have shown in the picture is a socket with the possibility of transmitting a satellite signal from the antenna to the tuner, and a socket with a TV and radio signal. Plug the TV input into the socket marked with the symbol or the inscription TV and it should work properly.
  • #3 7352512
    jikolp
    I have no idea about anything in this matter, I recently moved to the block and noticed something like that I thought that probably it will not be necessary to buy a room antenna
    can you tell me a total layman from scratch like TV to this, it is probably not some philosophy?
    I will be very grateful
  • #4 7354165
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    The caretaker (host) of the house knows everything. :D
    The cable from the "can" to the TV set is simple. Cable from the inscription TV (box) to the TV input.
    If you want to connect the signal to the box, you need to connect the antenna / signal cable to:
    How to connect and use an RTV antenna socket for TVP, TVN, Polsat channel reception How to connect and use an RTV antenna socket for TVP, TVN, Polsat channel reception
    Regards.
  • #5 7355716
    jikolp
    what for? I thought that this box was outputting a signal
    you can have any photo / name of this cable
    thanks
  • #6 7355769
    _LBX_
    Help: 17
    Rate: 92
    This is bringing the signal to your apartment. The cable is plain coaxial.
  • #7 7355821
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    jikolp wrote:
    I thought this box was outputting a signal
    Of course it does.
    The pictures show how the signal from the "cable" or "antenna" should enter the socket / box.
    How to derive a signal from this box, you also have shown / described in Your Own Drawing.
    TV - to the TV ( on the left side )
    R - to the radio (right side)
    SAT - for SAT tuner (top center, F connector)
    Any coaxial cable + two TV plugs to the cable [one female (to the box) and the other male (to the TV)].
    You can buy typical coaxial cables at any RTV store with a length of 2m, 3m and probably even 5m.
    If you want to make the cable yourself, use e.g. RG-6 of the correct length.
    Regards.
  • #8 7357314
    jikolp
    that is, as I want to get a signal from the socket, I use a concentric cable (intermediary = female plug, can-male TV plug) and I should already have basic tvp polsat tvn channels?
    and as for this quote, it's not too much the antenna or the cable goes to the socket? for what purpose? is there a page to read about it? thx kisses
  • #9 7358175
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 658
    It all depends - if you have (and what) signal - in that socket. :?:
    We do not know anything - where you are from - where and on what block you have your antennas - whether there is any installation (on the block), e.g. (former) Azart, Cumulative or SAT).
    You are on the forum as "anonymous" and unfortunately we cannot be called. "fairies". :D
    The best solution is to ask "someone" in the block if there is a TV signal in and what. :cry:
    The building administrator or building owner is 100% informed which network and "system" are installed in your TV installation.
    Regards.
The discussion revolves around the use of an RTV antenna socket for receiving television signals, specifically for channels like TVP, TVN, and Polsat. Users clarify that the socket can transmit signals from a satellite antenna and a TV/radio signal. To connect a TV, a coaxial cable should be used, with one end connected to the socket marked "TV" and the other to the TV input. The importance of checking the existing signal source in the building is emphasized, as well as consulting the building administrator for information on the installed TV signal system. Users also mention the possibility of using RG-6 coaxial cable for custom installations.
