Polsat Plate for Receiving Digital Terrestrial TV Channels - Using MPEG4 TV & Auto Tuning
bartass4 6375 8
  • #1 16189529
    bartass4
    Hello. The previous owner left me a plate of polsat which is already installed outside the window and can I receive digital terrestrial TV channels with this plate? I have a TV with MPEG4 but after auto tuning it did not find anything. thanks in advance for any help.
  • #2 16189559
    szymon122
    Help: 302
    Rate: 762
    There is no such possibility, you need a DVB-T antenna.
  • #3 16189570
    bogi
    Help: 103
    Rate: 244
    The plate is used to receive satellite TV. For digital terrestrial tv you need a suitable tv antenna (depends on where you live).
  • #4 16189592
    bartass4
    I understand I need a DVB-T antenna. location Bydgoszcz. what antenna do you recommend for terrestrial TV reception, I will add that there will be a short distance between the antenna and the TV set.
    another question, if I would like to receive satellite channels with this dish, how to do it?
  • #5 16189649
    szymon122
    Help: 302
    Rate: 762
    You need to buy a subscription, buy / rent a set-top box and connect it.
  • #6 16189814
    LeDy
    Help: 1992
    Rate: 2940
    And did he write that he wants to watch scrambled?
    A SAT decoder, preferably DVB-S2, is enough for reception from a satellite dish.
  • Clarifying DVB-T antenna terminology and cable distance
    #7 16189888
    niewolno2
    Level 40  
    Help: 630
    Rate: 1260
    bartass4 wrote:
    I understand I need a DVB-T antenna?
    Such antennas do not exist, you need to buy an antenna for terrestrial TV signal reception, abbreviated as DVB-t.
    You have about 20km to the transmitter plus the MUX-3 illuminating transmitter.
    http://www.dipol.com.pl/dobor_anteny_do_odbio...aziemnej_telewizji_cyfrowej_dvb-t__bib217.htm
    The distance from your antenna to the TV does not really matter here, we are talking about a distance of about 15/20 meters, I understand that my friend has a new antenna cable.
  • #8 16190457
    internick
    Level 36  
    Help: 273
    Rate: 555
    I will just mention that on MUX1, MUX2 and MUX3 an antenna dedicated to the UHF band, and on MUX8 an antenna dedicated to VHF. You bring the cables under the roof and connect the crossover with or without voltage transmission (cheaper). The option without the possibility of transmitting voltage can be used when both antennas are on a symmetrator.
  • #9 16190488
    KOCUREK1970
    Help: 3862
    Rate: 5490
    bartass4 wrote:
    location Bydgoszcz
    The room antenna (Bydgoszcz-Trzeciewiec transmitter) should pass the exam - you need to check it yourself.
    He probably wants to watch 3,000 free-to-air rubbish, including, of course, "free-to-air" TVP1 / 2, Polsat, TVN ...?
The discussion centers around the use of a Polsat satellite dish for receiving digital terrestrial TV channels. Users clarify that a DVB-T antenna is required for terrestrial reception, as the dish is designed for satellite TV. Recommendations for suitable antennas for the Bydgoszcz area are provided, emphasizing the need for a UHF band antenna for MUX1, MUX2, and MUX3, and a VHF antenna for MUX8. To receive satellite channels, a subscription and a DVB-S2 set-top box are necessary. The distance between the antenna and the TV is not critical, but a quality antenna cable is important for optimal signal reception.
