Electrolux ESL6270 Dishwasher: i30 Error Displayed - Causes and Solutions
a.barszcz 133519 14
  • #1 7356032
    a.barszcz
    I have an Electrolux ESL 6270 dishwasher, after setting the washing program and turning it on, the dishwasher turns off after 5 seconds, a buzzer is turned on - the pump pumps out the water, and the i30 error appears on the display - what is the reason?
    Greetings.
    spkb
    Help: 7
    Rate: 71
    This error indicates a leak, open the side cover and check if the pan is wet. If there is water, pour it out and check where it is coming from.
  • #3 7360031
    wersion
    Help: 13
    Rate: 112
    Error "i30" or LED 3 informs about the activation of the anti-flood system, as a colleague wrote above, a leak may have appeared. If there is no water, perform a fault reset
  • #4 8975863
    jamnikmar
    Rate: 14
    I encountered a similar problem in the Electrolux dishwasher (code 30) but after dismantling it turned out that there was a small hole in the drain hose.
    and of course a float with a limit switch that runs this code
    and the view from the other side of the float
  • #5 11132179
    Kaki
    In fact, the i30 error means flooding
    in my case, the problem was a badly fitted (or blown) gasket near the interior lamp.
    First, a flash, a shot, damaged it and (surprisingly) the reaction of both the fuse in the apartment and in the stairwell. At that time, I did not expect the damage to be caused by a leak. The dishwasher works properly, despite the absence of a light
    3 weeks later, the problem appeared again in the form of a terrible flash and, of course, the fuses were unplugged again (an interesting fact is that turning the dishwasher off does not disconnect the light, it is powered directly from the socket through the switch on the hinge).
    Due to the inability to pull out the dishwasher without disconnecting the drain and power cables (connecting it later is very tedious and difficult - a narrow small kitchen with built-in furniture), I was forced to combine to disconnect the cable from the hinge switch without unscrewing the dishwasher - I managed)
    I was slowly beginning to suspect a leak in the light ...
    Another 3 weeks later the i30 error appeared
    This time I had no choice but to remove the dishwasher.
    Searching for leaks, I did not come across any damage ... I looked at the light out of curiosity, what happened to it ... I saw a gasket stuffed inside ... everything was clear, the light was responsible for the leak.
    Currently, the dishwasher still does not have a light (damaged electronics). The gasket has been correctly installed, the housing is assembled, and additionally, it is stuck with Hybrid-Acrylic Adhesive on the inside, so that no more leakage there is ...
    A moral for the future - before you dismantle the guts of the dishwasher (drain pipes, etc., first check all gaskets, etc. in accessible places, e.g. a light.
  • #6 17618539
    k_kpok
    Rate: 14
    Hello, I use the Electrolux relife xxl ESL67070R dishwasher. I am getting an i30 error while washing program 1. It was already diagnosed by a service specialist and he did not find any leaks, he cleaned the hydrostatic system and I paid 100.
    It worked for 2 months and the same thing again. It's dry everywhere, and the mistake is there. I reset the dishwasher and set the rinsing program to the end without error, and if I choose a longer other program, the i30 error again. Maybe someone will advise where to look for the cause because my hands are falling. Road and terribly emergency, at least for me. Thanks for the tips.
  • #7 17618767
    peter falk
    Home appliances specialist
    Help: 1158
    Rate: 3355
    Since there is no water in the tray under the float, the solenoid valve on the supply hose is probably faulty.
  • #8 17624683
    k_kpok
    Rate: 14
    You came from repairs from the site. He checked everything, rebooted all the cables, twisted it and left. Fortunately, it only cost me PLN 20. Today I started 1 wash after his visit and it was finished, I am only curious for how long it will work.
  • #9 17642102
    Pani_domu
    Hi, in my case the i30 error also turned out to be a light leak. Is it possible to replace the gasket in the light from the inside of the dishwasher? Unfortunately, some fitter screwed the plate of the dishwasher cabinet to me and I cannot take it out ...
    Thanks in advance for the hints.
  • #10 17642262
  • #12 17787567
    offen
    Ladies and gentlemen,
    I have the same problem, described above - "stuck" gasket on the interior light and possibly an i30 error as a result.
    How is the "glass" of this lamp taken off? Does he twist? Questions? I don't want to break it, and with controlled force, it won't budge.
    I would like to add that I had not realized before that such a flaw could arise in this lamp. I wanted to take out the dishwasher and check the guts. When the i30 error appeared, after a few days the dishwasher came to life and worked for a few days, and then again the i30. Perhaps, when the water that got on the electronics through the leaky gasket dried, the dishwasher worked. All in all, let it be just that :)
    Thanks for the help in advance.
  • #13 17787818
    zhudomel
    Help: 1280
    Rate: 3362
    offen wrote:
    I already wanted to pull out the dishwasher
    And good, because otherwise you will not seal the lamp.
  • #14 17788511
    peter falk
    Help: 1158
    Rate: 3355
    And you won't pull it out. You need to remove the right side wall of the dishwasher.
  • #15 17819719
    pawelvrh
    Rate: 15
    For me, the ELECTROLUX ESL 66020 dishwasher after 10 years of trouble-free operation (except for the failure of the lighting lamp) reported the i30 due to a broken wire in the bundle between the door and the body.
    The bowl was dry, the water valve after the test, giving it 230V, turned on water, so as described, the wiring for inspection.
    The wires are fixed and the work is on :-)
    ELECTROLUX ESL 66020 i30 error
    Electrolux ESL6270 Dishwasher: i30 Error Displayed - Causes and Solutions1.JPG (66.08 kB)You must be logged in to download this attachment. ; Electrolux ESL6270 Dishwasher: i30 Error Displayed - Causes and Solutions20190303_1...4649_1.jpg (2.69 MB)You must be logged in to download this attachment. ; Electrolux ESL6270 Dishwasher: i30 Error Displayed - Causes and Solutions20190303_1...4820_1.jpg (2.53 MB)You must be logged in to download this attachment.
✨ The i30 error on the Electrolux ESL6270 dishwasher indicates a leak, triggering the anti-flood system. Common causes include water accumulation in the base pan, faulty gaskets (especially near the interior lamp), and issues with the drain hose. Users have reported that inspecting for leaks, resetting the fault, and checking the solenoid valve on the supply hose can help diagnose the problem. In some cases, the error persisted despite no visible leaks, suggesting potential wiring issues or problems with the hydrostatic system. Solutions involve checking for leaks, replacing gaskets, and inspecting wiring connections.
