[Solved] Electrolux ESL 46010 - i30 - Electrolux ESL 46010 - Error i30 - flooding
matecz 12228 2
  • #1 17016460
    matecz
    Hello everyone,
    A few days ago the Electrolux ESL 46010 dishwasher refused to show error i30 (browsing the forum, I found out what it means). Today, I dismantled the side walls of the dishwasher and it turned out (it is not strange) that there is water in the tray at the bottom. For diagnosis, the water was removed and I started the dishwasher program to find a leak. It turned out (what I tried to capture in the pictures - unfortunately the access is terrible) that it is clearly dripping from the washing pump (after all I will throw some illustrative pictures - maybe I can advise you on something). Here is my question - does this mean that the entire pump needs to be replaced or potentially some seals? Alternatively, can you get to this pump from the bottom of the dishwasher so I can take more photos?
    bubu64
    Help: 57
    Rate: 283
    If the leak is on the pump seal, the entire pump must be replaced :)
  • #3 17036961
    matecz
    Buying a new dishwasher.
