Dishwasher Electrolux ESL5320LO - error i30 water leakage to the bottom of the d
Zbyszek_64 12678 5
  • #1 16988473
    Zbyszek_64
    Help: 66
    Rate: 296
    The dishwasher sends water into the bowl through a hose attached to the pump on the left side and signals an i30 error. Sometimes he will do 1.5 hours washing and throw 2l of water. The dishwasher is built-in, so I delay with its possible disassembly. I have a question about what may be the cause of the leak. The second visible tube is dry. I am asking for suggestions.
  • #2 16989094
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    Hello. At the beginning I would check that the bottom propeller is not glued to the sides, then to check the door seal.
  • #3 16989125
    zhudomel
    Help: 1280
    Rate: 3373
    To clean / replace the hydrostat.
  • #4 16996799
    Zbyszek_64
    Help: 66
    Rate: 296
    I dismantled the hydrostat and I do not know how to check it. Is it even demountable?
    zhudomel
    Help: 1280
    Rate: 3373
    Looking along the bend on the paper, the hydrostat is on the left. Unlock the latch between the black and white plastic (to the right of the orange dot), disconnect and clean the hydrostat tube that you will see then.
  • #6 16999384
    Zbyszek_64
    Help: 66
    Rate: 296
    I did not dismantle the hydrostat because I was afraid of its damage. However, after disconnecting the hydrostat, I cleaned the connecting tube with the pump. A cork made of leftover food came out of it. The dishwasher has made two large washing and dry bottoms. All in all I could do this cleaning without dismantling the dishwasher, but the experience is priceless. Next time I will know what to go for.
    Thanks for your interest and best regards.
