Electrolux ESL 48900 - all I need is to do the i30 error reset
rafalmuzg 31326 4
  • #1 16440723
    rafalmuzg
    Rate: 21
    I warmly welcome,
    I urgently need to do an error reset on the Electrolux model ESL 48900 dishwasher. Someone knows how to do this. I give the diagram of the buttons:
    1 - on / off button
    2 - display
    3 - touch field to delay program start
    4 - touch screen for selecting programs in
    5 - touch screen for program selection up
    6 - touchscreen for energy-saving mode
    7 - touch field of the Multitab function
    8 - touch field
    9 - indicators.
    best regards
    zibi1971
    Home appliances specialist
    Help: 262
    Rate: 1120
    Clear the reason for the error first. If you do this, the error will disappear by itself.
  • #3 16440888
    rafalmuzg
    Rate: 21
    The wife poured too much liquid and the foam was made. I have rinsed the dishwasher chamber many times but the pump is still working with i30 error, i.e. flood protection has been activated. How to fix it?
    zibi1971
    Help: 262
    Rate: 1120
    Unscrew the side of the dishwasher (right) and remove the water from the bottom tray.
  • #5 16440980
    rafalmuzg
    Rate: 21
    Thank you very much for your help. I did as you wrote and the dishwasher works back properly. Best wishes.
