RJ-45 Ethernet Cable Wiring: T568A vs T568B Color Order for Modem-Router Connection
bkroy 98964 13
Why does one RJ-45 color order work for a modem-router cable while the other does not?
Both straight-through RJ-45 wiring schemes should work; if one does not, the most likely cause is a bad crimp, a pinched contact, or a damaged conductor, not the color order itself [#7381132][#7382448] Ethernet uses pins 1, 2, 3, and 6 for transmit/receive, so those conductors must actually be making good contact [#7382005] If the cable works after changing the order, that suggests the original plug was wired or crimped incorrectly, or one vein was faulty [#7381132] A LAN cable tester is recommended to verify both the crimp and the cable continuity [#7382448] In practice, the pair colors can be arranged as long as the plug is terminated correctly and the pairs are matched properly [#7382448]
  • #1 7381116
    bkroy
    Rate: 30
    I admit that I have not dealt with building a network, but I have a question.
    I have patched the network cable to connect the modem-router according to the colors in the following order:
    white-orange
    orange
    white-blue
    blue
    white-green
    green
    white-brown
    brown
    On both sides the plug was tight and the network did not work (no net, no automatic ip).
    By changing the order on both sides to:
    white-orange
    orange
    white-green
    blue
    white-blue
    green
    white-brown
    brown
    Everything is OK...
    The malice of inanimate things, what is it?
  • #3 7381740
    Boqler
    Help: 5
    Rate: 11
    Hmm, I use the latter and it always works. Ew is changed from orange to green - also should work.
  • #5 7381849
    bkroy
    Rate: 30
    witux wrote:
    After all, the cable clamped according to options 1 and 2 is symmetrical on both sides ... So why 1 does not work?
    The best part is that they recommend Option 2 everywhere which is:
    white-orange
    orange
    white-green
    blue
    white-blue
    green
    white-brown
    brown
    Weird line with these colors, but I'll squeeze again and check ;)
  • #7 7382393
    abdenagof
    Help: 58
    Rate: 28
    It does not work because different colors have different frequency of twisting the wires, with longer sections the crosstalk is too high and the transmission is transformed.
  • #8 7382448
    wojtek_1985
    Rate: 12
    All the wires are twisted in the same way, in practice, the colors of the wires can be changed and it will not have any effect on the operation, as for the length, theoretically up to 100m should work, in practice, using a good cable, you can reach up to 200m.
    A lan cable tester would be useful here, after checking the correct clamping of the wires, you can also check whether the cable is functional.
    PS
    There may also be a problem with twisted pair transmission if the LAN cable goes parallel to the power cable in a close distance of
  • #9 7382596
    abdenagof
    Help: 58
    Rate: 28
    wojtek_1985 wrote:
    All the wires are twisted in the same way, in practice you can change the colors of the wires and it will not affect the operation,
    You can see buddy that you have never had contact with computer networks and you like to make posts.
    Link
    In addition, in the 100m section of the twisted pair, individual pairs are of different lengths, the differences reach about 15% between the longest and the shortest pair
  • #10 7388754
    wojtek_1985
    Rate: 12
    Link
    This is just a disadvantage, not an advantage (you can even read it from your link).
    These length differences are not the result of transmission, but of twisting inaccuracies, the best situation is when all pairs are twisted in the same way, which is not possible in practice.
    And below is a quote from the page from your link:
    A parameter closely related to the delay is the delay spread (DELAY SKEW). This parameter results from the construction of the cable, because each pair of wires is twisted with a different pitch, which means that they have a slightly different length. This parameter plays a particularly important role in technologies that use all four pairs for transmission - Gigabit Ethernet. The acceptable difference between the "fastest" and "slowest" pair is 50ns over a distance of 100m. If the measurements show a dangerously high spread and we are dealing with applications using 2 pairs (10Base-T), the system should still work, unfortunately, in the case of networks using 4 pairs, exceeding the allowable threshold is most often the source of transmission failure.
  • #11 7390122
    abdenagof
    Help: 58
    Rate: 28
    If all pairs were to be twisted the same along their entire length, it would be so, but wise engineers did not accidentally design the cable in this form. Worse than the spread of lags would be the mutual interference if the pairs had the same turning radius. That is why colors should be adhered to, because network cards expect that the pair used for transmission has the appropriate length and radius of twisting in relation to other pairs, if we change the colors, distortions and transmission errors may occur
    below a quote from Wikipedia, which clearly shows that the twisting is not a coincidence, the current technology allows the construction of a cable with evenly twisted pairs
    Twisted-pair wire - a type of signal cable used to transmit information, which is made of one or more pairs of twisted copper wires, with each pair having a different twist length to reduce mutual interference , known as crosstalk. Twisting the wires causes the transmission band to be narrowed at the same time.
  • #12 7391244
    wojtek_1985
    Rate: 12
    When it comes to what is written there, I approach what is written there with the appropriate distance - in the end, each of us can write what we want. And I have never heard of a different twist, so I also approach it with a distance.
  • #13 7391366
    abdenagof
    Help: 58
    Rate: 28
    It is proposed by my friend an educational game, take a 2m section of the twisted pair, remove the outer protective layer and post your observations on the construction and twisting pairs on the forum. Maybe your distance will decrease.
  • #14 7391392
    wojtek_1985
    Rate: 12
    Maybe I will not destroy the cable, but I clamped different colors many times, but so that the pairs match and it always works.
The discussion revolves around the correct wiring order for RJ-45 connectors in network cables. The original wiring order provided by the user did not function, while a modified order did. Responses suggest that both wiring configurations should theoretically work, but issues may arise from improper pin connections, damaged wires, or differences in wire twisting frequencies. It is emphasized that adhering to standard wiring color codes is crucial to avoid transmission errors and ensure proper functionality, particularly for Gigabit Ethernet applications. The importance of using a LAN cable tester to verify connections and functionality is also highlighted.
