Correct Color Order for Creating a 1:1 LAN Cable: Guide and Resources
DJOstry 81987 9
What is the correct wire color order for making a 1:1 Ethernet LAN cable?
For a 1:1 Ethernet cable, wire both ends to the same standard—T568A or T568B—and keep the pair order exactly as specified [#2506992] T568A is: 1 white-green, 2 green, 3 white-orange, 4 blue, 5 white-blue, 6 orange, 7 white-brown, 8 brown [#2506992] T568B is: 1 white-orange, 2 orange, 3 white-green, 4 blue, 5 white-blue, 6 green, 7 white-brown, 8 brown [#2506992] Several replies note that the pairs are what matter, but it is still best to follow a standard so the cable is easy to maintain and works reliably in a network [#2507293][#2507649]
  • #1 2506854
    DJOstry
    Help: 11
    Rate: 65
    Hi !
    Yes, someone is at hand on a quick basis ??
    I need 1: 1, maybe some link.
  • #3 2506992
    *mondzio*
    Level 30  
    Help: 132
    Rate: 54
    DJOstry wrote:
    Hi !
    please
    Sequence of wires according to the 568A standard
    1. white-green
    2. green
    3. white and orange
    4. blue
    5.white-blue
    6. orange
    7. white-brown
    8. brown
    Sequence of wires according to the 568B standard
    1. white-orange
    2. orange
    3. white-green
    4.blue
    5. white and blue
    6. green
    7. white-brown
    8. brown
  • #4 2507154
    humek
    Level 32  
    Help: 170
    Rate: 164
    here the colors do not matter, pairs are counted and the colors are a conventional thing.
  • #5 2507293
    Rob
    Level 19  
    Help: 25
    Rate: 33
    Maybe the colors don't matter. But if there is a standard, you should stick to it. Think if someone connects the phase in the electrical switchboard to a yellow-green cable :) .
  • #7 2507548
    DJOstry
    Help: 11
    Rate: 65
    colors matter, and a lot of it :) ))
    at 5 meters, the colors may not matter, but at 40 meters it is already May. I checked it.
    If I earn as I want, there is no connection, the meter shows the correctness of the connection (LINE TEST) and if I earn according to the standard, it is a 100 MB connection.
    no..no sorki ... pairs count :) you are right buddy. I got it wrong :)
  • #8 2507649
    forestx
    Rest in Peace
    Help: 299
    Rate: 496
    Despite the fact that the topic has already been rolled over many times ...
    You write: pairs count. That's right. If you are making a 5m cable, the colors are not important. But when making a network (several dozen points), a standard must be kept. Even for the man who will be rummaging in this network in a year.
  • #9 5961857
    marek-gudzowski
    Rate: 11
    what connection did he use to connect the computer to the router? oblique or straight ??
  • #10 5962271
    Krzyq
    Help: 46
    Rate: 32
    And you were not interested in why you usually have problems with one cable? And why is it brown / orange most often (depending on the manufacturer), but blue tends to break?
    CISCO specialists may not explain to you how to calculate integrals, but you may find out why colors are important also for safety reasons. It is enough to read a little. In home and non-professional networks it will work because most often only 4 wires are used and for short distances ... It is also good to wear collars for it to work, but do not complain about the stability and loss of the connection.
    By the way ... I wanted to laugh when I saw alarm systems in Dolnoślonskie, connected in such a non-trivial way that it was possible to download the image directly from the cameras, without the control panel knowing ^ _ ^. To make it funnier, the systems were set up by electrical engineers who, as it turned out after the interview, had never heard about electromagnetic induction more than ever.
The discussion revolves around the correct color order for creating a 1:1 LAN cable, referencing the T568A and T568B wiring standards. Users emphasize the importance of adhering to these standards for maintaining network integrity, especially over longer distances. While some participants argue that color coding may not matter for short cables, others stress that following the standard is crucial for future troubleshooting and network reliability. Links to resources and diagrams are provided for further guidance.
