Setting Channel Power Levels on Motorola GM 300 Using RIB-A Cables
piraniamax 7084 18
How do I set different transmit power levels for individual channels on a Motorola GM300 using RIB-A cables?
Program each channel in the “Per Channel” section and assign it “Low” or “High,” then set the actual Low and High power values in the “Per Radio” RF tab [#744502]
  • #1 743225
    piraniamax
    I wanted to ask how to set the power for a given channel, I need one channel to have less power and the other bigger one and I do not know how to do it. I have rib-a soft cables. Thank you in advance for your help.
  • #2 744502
    sp5mbx
    You program the "Per Channel" radio, eg 1 and 2 channel - there you choose Power Level "Low" or "High" and then in the "Per Radio" - RF tab declare the power of Low and High. that's it. :)
  • #3 744950
    IjeSJot
    Help: 84
    Rate: 40
    Well, maybe someone knows how to program the GM300 scan ??? I have 8 channel versions and expanded to 16th Band 146 - 174MHz.
    Regards IjeSJot.
  • #4 749771
    piraniamax
    as for the scanner, the microphone must be on the handle so that the scanner works, and press the scan for 3 seconds. and you set yourself what channel you want to deposit. As for the power, sp5mbx colleague described how to program the power in motorola gm 340 radios and similar (i think so), i.e. from the new motorola series, and gm 300 only have the softa just under dos, unless a colleague sp5mbx has something under the windows I would ask for contact. I would like to ask you what version of the program my colleague sp5mbx has, for motoroli gm 300. Thanks in advance for your help :)
  • #5 750498
    IjeSJot
    Help: 84
    Rate: 40
    Well, in the attachment you have a program for windows :D
    Just explain why this windows viewer does not see my programmer ??? And the DUN sees !!! I have run it after XP and 98 and can not see in each of them (DOS works without a problem like XP and 2000 and also 98 :D
    And as for the hook from the microphone it is in the DOS program, whether it is this hook or not ... and I care very much on the scanner ...
    Regards IjeSJot.
    • gp_gm300_03_01_02.zip (4.22 MB) You must be logged in to download this attachment.
  • #6 750538
    piraniamax
    Chmm where is this attachment with this program under windows ?? :)
    I have a 16 channel version of motorola and a dos program, I set up a scanner and I mean, I do not know what the problem with this scanner is. :)
  • #7 750548
    IjeSJot
    Help: 84
    Rate: 40
    Well, how do you not see the attachment ?? :| And maybe you are not logged in :D
    And when it comes to the scanner I read that the 8 channel versions had this problem :( And I just expanded 8 channels to 16 and when I turn on the scan is a radio stands in place :(
    And what is the mon LED for? because u does not light up all the time and I can not see what's going on.
    Do you have any instructions for programming such a skein?
    Because I also do not know what the FORCED MONITOR option is for or somehow :)
    Regards IjeSJot
  • #8 753342
    piraniamax
    write what's happening when you turn on the radio. The "mon" LED lights up and when you press the "mon" button, what does the diode go off ?? write what happens when you press the "scan" button blinks alternately dash (dashes) and channel number ??
  • #9 753348
    piraniamax
    apropo with this program you can program only motorola from the gp 320 and gm 340 series, etc. I have one and you will not be able to communicate with gm 300 and it does not mean that you have something wrong with rib, I have gp 380 and this program comes from this trx
  • #10 753373
    IjeSJot
    Help: 84
    Rate: 40
    The mon diode lights up all the time ... even as you push ...
    As the scan is slow, only one frequency flashes and does not scan at all. :(
    So why did they write that the program supports gm and gp300 ??? :(
  • #11 753433
    piraniamax
    series "300" gm and gp support from the new version, if the channel number and horizontal line are flashing, any scanner will not scan, touch the microphone foot to the mass of radja and write what happened? did the mon diode go out? (if it is not on the affected bulb, press the mon key and does the mon LED go out?) did it stop blinking and the dash started to burn all the time?
  • #12 753835
    IjeSJot
    Help: 84
    Rate: 40
    Can you send me this program by email or post here ???
    Well, I touch as you say and nothing happens. :(
    Or maybe it has something in common with this Forced monitor function in the program ??
  • #13 753924
    piraniamax
    Here is the program for gm 300
    • gm300.rar (277.58 KB) You must be logged in to download this attachment.
  • #14 753937
    piraniamax
    rip the contents of your motorola and send me a peek, piraniamax(_at_)tlen.pl address
  • #15 753939
    IjeSJot
    Help: 84
    Rate: 40
    Thanks but unfortunately your program does not see my radio because it's too old, I have a program from 94 years and yours is 93 ...
    I do not know what's going on with this scan ... :(
    Regards IjeSJot
  • #16 754034
    piraniamax
    do you have 70 cm radios ?? these files have not been saved well please send again, just make a new directory and save what the program will save and send me the whole catalog
  • #17 754058
    IjeSJot
    Help: 84
    Rate: 40
    This is the version at 146-174MHz. I do not know why I wrote badly :|
  • #18 762070
    piraniamax
    Send me this file again from motorolka save it in another directory and pack it pozdr.
  • #19 762075
    IjeSJot
    Help: 84
    Rate: 40
    Unfortunately, I had to give away the programmer and I did not survive. :( but I'm working on my rally soon I will have my own and send these files.
To set channel power levels on the Motorola GM 300 using RIB-A cables, users can program the "Per Channel" settings to select "Low" or "High" power levels for specific channels. The RF tab under "Per Radio" allows for the declaration of power levels. Some users have reported issues with programming and scanning functions, particularly with older versions of the GM 300 and compatibility with software. The discussion also touches on the need for a microphone to enable scanning and the challenges faced when using different programming software versions.
