Motorola DP1400: Programming Guide for Motor Bike - Getting Started with Digital Radios
BorysPP 16194 9
How do I start programming a Motorola DP1400, and what cable/software do I need?
To program a DP1400, you need the proper cable and CPS software; once you know the bands and channels you want, entering a few channels is straightforward [#16411582][#16413060] One user reports that a normal USB-to-micro-USB cable with MotoTRBO drivers is enough, because the radio is detected as a network card and works with DP1400 CPS EMEA v11.5 [#16421087] If the radio does not connect, the problem may simply be the cable, since another user tried many mini-USB cables before one finally worked [#16709676]
  • #1 16409284
    BorysPP
    Rate: 15
    Hello. I am asking for a hint regarding the programming of the DP1400 motor bike. There is a similar post on Motorola programming topics, but as I see the answers are on PRIV. I understand why :) but it didn't help me at all ...
    Thank you in advance to a good soul who will help me. I'm just starting to play with the digit.
    Best regards.
  • #2 16411582
    Moskit
    Help: 17
    Rate: 39
    Cable + program do you have?
  • #3 16413060
    worek110
    Help: 17
    Rate: 46
    Knowing the bands you want to introduce to the radio + cable and the program I wrote MOSKIT
    there is no philosophy to introduce several channels, it would be better if you said what, specifically you ask what the problem is.
  • #4 16413503
    BorysPP
    Rate: 15
    Of course there was a problem with the cable. Unfortunately, the next one will come after Christmas.
    By the way, I wish you all a Merry Christmas. Best regards.
    ps. I ordered - PMKN4128A programming cable. I hope this one will be ok.
    solarssk
    You say interesting things about this cable. I use a normal USB to micro USB cable with the MotoTRBO drivers downloaded (now I don't even remember where from, but they are on the net - it detects you motorolka as a network card) and go. It works. I am using up to 4 DP1400 CPS EMEA v11.5
    Best regards,
    Philip
  • #6 16441614
    BorysPP
    Rate: 15
    I let go of the programming cable because nothing works with it. For a change, I tried everything possible under the micro usb but it does not recognize the device in any way.
  • #7 16443401
    worek110
    Help: 17
    Rate: 46
    What windows operating system?
  • #8 16444591
    BorysPP
    Rate: 15
    I generally use XP for programming, but have 7 and 10 in laptops.
  • #9 16445078
    worek110
    Help: 17
    Rate: 46
    I don't know how it goes on these systems, I work on 8 and there is no problem. I write more to you on pw
  • #10 16709676
    BorysPP
    Rate: 15
    Problem solved. The reason was in the cable. I tried on 10-12 cables with a mini usb connector and for no other reason on one it finally connected :)
    best regards
The discussion revolves around programming the Motorola DP1400 digital radio for use with motorbikes. The original poster seeks assistance with programming, specifically mentioning issues with the programming cable. Responses highlight the importance of having the correct programming cable and software, with suggestions including the PMKN4128A cable and using a USB to micro USB cable with MotoTRBO drivers. The author experiences difficulties with multiple cables but eventually resolves the issue by finding a compatible cable. The conversation also touches on the operating systems used for programming, including Windows XP, 7, and 10, with varying success reported across different systems.
