I’ll take this opportunity to respond to a few of shorti13’s comments, which, to put it diplomatically, are greatly exaggerated:
Quote: 1) Controlling heating via the IB system is only possible in KNX/EiB.
As I wrote above, heating control can be achieved by regulating the power supply to individual heating circuits. As for integration with the boiler’s automation system, whether and how the boiler can be controlled by external IB-type devices depends largely on the boiler’s design and the manufacturer’s policy. As for an exemplary controller design – in my opinion, not a KNX-based one – take, for example, the NIBE Fighter1245 heat pump. I hope other manufacturers will follow suit [excerpt from the technical documentation in the attachment]. Not only does Nibe provide 5 contactor inputs on its pump control unit, but it also allows you to select which specific tasks a given contactor should perform during the pump’s operation. On top of that, of course, there’s an output with an alarm function. Solutions more or less similar to this are becoming increasingly common on the market when it comes to boilers, air conditioners, heat recovery units, etc. No KNX gateways are required.
As for the manufacturer’s ‘preference’, that is another matter entirely… Simply put, boilers, by their very nature, should not allow too much scope for manipulating the fuel combustion process… mainly to protect the user from potential harm resulting from excessive or incorrect interference.
Another thing is that sometimes it’s claimed that something is a KNX controller, but when it comes down to it, it turns out to be just ordinary binary inputs/outputs, which I suppose any IB system can handle.
Quote: If I can’t afford a KNX-compatible boiler to control the valves, one might be tempted to use what I call ‘proprietary’ systems (manufactured by a single company), but this comes with a rather significant problem – what if that company goes bust? We’d be left with no way to expand or repair the system. That’s why, for valve control too, I’d choose KNX as the system, as its components are produced by many financially independent companies.
That is indeed a valid point. It’s just a shame that products from the KNX consortium are so expensive that one could easily order (for particularly cautious customers) a 100% stock of spare parts, and it would still be cost-effective. As for servicing and repairs, this is generally electronics based on fairly tried-and-tested and popular technologies, so I imagine any workshop that repairs any sort of control unit would be able to handle the servicing. Another point is long-term service contracts. Not every customer is aware of this, but any manufacturer that decides to work with an institutional client signs a long-term contract for the servicing and maintenance of the installation in question. Of course, KNX offers the greatest peace of mind in this regard, but it is probably not proportionately expensive (since even integration with boilers via a gateway is a dead-end service, as hardly anyone would agree to such a costly solution). As for development… Expandable installations were created because the upfront cost of the whole system is simply too high. In the case of these ‘proprietary’ solutions, the development of the IB system stems more from a fascination with the technology than from financial constraints… although that does happen too, and the possibilities in this regard are by no means any less.
Quote: 3) When it comes to cutting costs and bypassing KNX, I’d skip controlling the heating via the IB and leave it to the furnace manufacturer. As for the other controls (lights, blinds and so on), he controlled them using any system, provided it involved routing the circuits to a single distribution board, as there are at least several such control systems available. Advantage: in the event of a fault, you’ll still be able to switch the lights on somehow, and you’ll have heating.
As for ignoring the heating and leaving the boiler alone, I’m in favour of that – or rather, against it
I also partly agree regarding the centralised system. Whenever we bring everything back to the distribution board, whichever system we choose, we’re left with the luxury of being able to manipulate these resources almost at will. It’s just that there’s one fundamental problem… Centralised systems are very labour-intensive, costly, and their size can grow to monstrous proportions even for homes that aren’t particularly large. Here, I’d like to mention Nexwell’s TUKAN technology, which adapts to the infrastructure of a standard electrical installation. These devices operate independently of the system’s control unit, so a potential fault does not cause an electrical blackout in the home. Retaining the infrastructure typical of a standard electrical installation is precisely what allows you to prepare your home for smart home technology at low cost.
Quote: I do, however, have a question: is there a KNX video doorphone?
Still not available? I thought it was practically standard in new builds by now...
