Nissan Micra K12 2003: Erratic Wiper Motor Behavior on Cold Start-up
autobus55 38034 17
Why do the windshield wipers on a Nissan Micra K12 start acting erratically on cold start-up or when the ignition is turned on?
The most reported fix is to add a 2.7–3.3 kΩ resistor in the steering-column switch harness between the +12 V feed and the washer-button ground signal, because the Micra K12 can falsely detect a washer/wiper command; this solved the fault for one owner [#8345568][#11711930][#11764047][#11823526] One contributor identified the white wire as +12 V with ignition on and the orange wire as the wire that goes to ground when the washer lever is pressed [#11764047] Another reported cause is a corroded washer-motor connector/cube under the steering wheel area; the advice there was to disconnect it, clean it, dry it, and reconnect it [#11821704] Replacing the switch alone did not solve the problem in the thread [#7808075]
  • #1 7721103
    autobus55
    I have a Nissan Micra in which the wiper motor goes crazy when the ignition is turned on, but not always, most often with a cold car and not when after starting the engine, when the voltage increases, the limit switch in the engine is ok or someone has encountered such a fault
  • #2 7726282
    BUZ11
    Rate: 36
    I assume the car doesn't have a rain sensor.
    The system is relatively easy to control, but diagnosis without Consulta will be difficult. Probably the problem lies in the IPDM module, which is hidden under the left headlight. To get to it, you have to remove the bumper and the headlight itself. Water probably got into it (a common occurrence). Alternatively, it remains to disconnect the wiper switch and check if they turn on then. There were cases of damage to the switch itself.
  • #3 7730800
    autobus55
    the rain sensor is nowhere to be seen, the module under the headlight is dry because I checked, and this module under the board next to it was rubbed against the bracket, I have the switch ordered for checking
  • #4 7757170
    diodakus
    Rate: 19
    You solved the problem of switching on the wipers - what was the reason?
    I have the same year of birth and the same symptoms.
    I didn't get a reply - so I had to stress and ... I did :D .
    Windshield wipers don't go crazy anymore.
  • #5 7808075
    autobus55
    welcome back
    the wipers are still crazy, replacing the switch did not help,
    the temperature on these wipers does not like it when it is cold, there is a moment that they start when the voltage rises, I connected the relay that cuts off the current to the motor because I cannot find the reason for switching on.
  • #6 8344966
    buulee
    Rate: 69
    I didn't get a reply - so I had to stress and ... I did it :D .
    What was the cause ??
  • #7 8345568
    diodakus
    Rate: 19
    And just as someone does not want to play with the modification, he can replace the washer motor in the tank with a NEW one (it's nothing that the one that works!). The NEW one will work until its winding is soaked with water and then it starts shorting to ground and the electronics detects that the wipers are on! (because electronics from the French taken (Renault) and not suited to this car)
    The problem is in the steering wheel switches - the + 12V shunt resistor is missing. It is enough to unscrew the plastic housing above the steering wheel switches - in the bundle to the switches above the steering wheel, you need to find a cable for switching on the washer (the mass appears on it after pressing the spray) - and solder a 3.3 k? resistor to it and the other side to + 12V - it is also in these cables - the resistance can be reduced (e.g. 2.7k? ;) if they still turn on by themselves.
    It took me some time, but let the owners take a break from the services that replace switches and modules for a lot of money and still will not remove the defects.
    Regards
    :D
  • #8 8345612
    buulee
    Rate: 69
    I also heard something about this motor from the pump - but you did not want to believe it, and here is a logical answer.
    Tomorrow is testing - how it really works - YOU'RE GREAT :D
    PS:
    I am still fighting in this micra 1.2 benz with the problem: https://www.elektroda.pl/rtvforum/topic1729740.html - maybe you will suggest something :?:
  • #9 9154304
    perzot29
    Rate: 11
    I also have a problem with the self-activating front wipers in the K12 micra. They activate despite the switch in the OFF position. I have a rain sensor. I noticed that it happens when it is wet (e.g. it rains) or when it is dry and I will go to the car wash. What could be the reason? Is this also a problem with the washer motor ????
  • #10 10580945
    MIMA267
    Rate: 26
    On the Nisan K-12, the wipers are automatically turned on, whether it is wet or dry.
    Despite a few notes on this subject, I did not find any specific or such that could be understood by not a layman, but poorly familiar with the structure of this car.
    Some phrases are such "yard slang" written that it is not known what the author meant.
    I am asking for some advice regarding the self-activating wipers in this car.
  • #11 10580953
  • #12 11420208
    loizy34
    Rate: 8
    Hello, I do not want to start a new topic, but my problem is that after switching the wipers to the position of the wiper automat, they work with a uniform, fast gear, it is not possible to set a blunt speed, the time potentiometer works once, but very little when, k12 2003 year
  • #13 11711526
    MIMA267
    Rate: 26
    Unfortunately, changing the pump motor to a new one did not help.
    Please write something more about installing an additional resistor.
    For several hours I was looking in the ankle above the steering wheel - I did not find the ground connecting cable when the washer was turned on. Maybe not this cube ?. When I disconnected it, the windshield wipers started to work, but without the washer pump.
    12V cable - found.
    All wires in this car model should be made in the same colors, so please give a hint, maybe after the colors I will get to the "ground" and the correct "12 V".
  • #14 11711930
    diodakus
    Rate: 19
    I have repaired this model a long time ago. I don't remember the colors of the cables - if someone finds it, please write it down.
    We only check everything on this cube of the cable harness for the switches above the steering wheel.
    1 - You need to take a test tube - connect one end to ground and look for + 12V in this plug with the tip - the ignition key.
    2 - As we already have + 12V - connect one end of the test tube to the + 12V cable and use the tip to look for "MASS" after pressing the washer button.
    3 - Once we find this "MASS", take (buy) a 2.7k? or 3.3k? resistor and install between these 2 cables (+ 12V and the "MASS" from the washer button).
  • #15 11764047
    MIMA267
    Rate: 26
    Today I soldered a resistor, but I will find out if anything helps until tomorrow during the trip.
    If you have the same structure of the switch as shown in the attached photos, then the white wire is + 12V (with the ignition on), and the orange wire is connected to the "ground" when pressed with the washer handle. I connected these wires with a 3 KOhm resistor (because according to Mr. Piotr's proposal, I did not have such values, and the difference is small.
    When it comes to disconnecting the ankle, this is the one on the left from the top. In order to disconnect it, press the catch located in the middle of the ankle quite firmly and carefully pull this part from the side of the cables together with the cables. It's quite hard to pull out, so don't pull the cables, you just have to deal with the rim of the ankle.
    Save show
    Save show
  • #16 11821704
    stepien792
    The problem is in the washer motor, and exactly in the ankle which is 100% tarnished !!!!
    Disconnect the cube, clean it, dry it, plug it in and do not work with any resistors because later no one will get it when something goes wrong
    I know because this problem also caught up with me and I was combining so much that I had to buy new shifters
    Regards
  • #17 11823526
    MIMA267
    Rate: 26
    I found the right wires and installed the resistor.
    The failure has been removed.
  • #18 11975427
    andriup23
    Rate: 8
    Hello. Someone could send photos of these cables because MIMA267, in the posts above, do not work. Thanks.
The discussion revolves around the erratic behavior of the wiper motor in the 2003 Nissan Micra K12, particularly during cold start-ups. Users report that the wipers activate unexpectedly, often when the vehicle is cold or wet. Potential causes identified include issues with the IPDM module, wiper switch malfunctions, and problems with the washer motor. Solutions proposed include checking for water damage in the IPDM, replacing the wiper switch, and installing a resistor to stabilize the electrical signals. Some users have successfully resolved the issue by cleaning connections and replacing faulty components, while others continue to seek solutions for similar symptoms.
