Nissan Micra k12 1.2, after firing revs are waving, it fires hard
dawid46stg 10650 6
  • #1 16782287
    dawid46stg
    Hello, I have a problem with micra k12 1.2. The car starts hard, after firing, the revolutions wave for about 5 seconds and calm down, but the car can go out even while driving.
    He was at a few mechanics, they replaced the throttles, after this operation the revolutions were still waved a bit but did not go out for a few weeks. Now the problem has started to appear again, more and more often it goes out while driving. On my own I changed the variable phase sensor, lambde probe (after removing the old one it was all black and not ore), candles, I checked the pressure on the pistons is ok, and I replaced two coils.
    The check engine lights up in the ignition, I checked the code and it displayed p0300 and p0340.
    Thank you for your help,
    Regards.
  • #2 16782699
    DriverMSG
    Help: 3984
    Rate: 4883
    Check the tightness of the intake system. It is possible that it is pulling "left" air.
  • #3 16806865
    dawid46stg
    I checked the tightness, everything is fine.
    The condition has worsened, I read from the error that there is a camshaft position sensor error. After firing the car goes out and, oddly enough, death with oil, despite the fact that gasoline is flooded.
  • #4 16806905
    DriverMSG
    Help: 3984
    Rate: 4883
    Maybe someone made a mistake refueling?
    Check the camshaft position sensor - contacts, mounting / positioning, or substitution if necessary.
  • #5 16806980
    dawid46stg
    Nobody probably got it wrong, because it smelled of oil before and I went to refuel gasoline specially, because I already considered this option. I wonder one thing, why rpm wave after starting the engine, that until it goes out if it does not gas properly and after a few seconds it calms down? Can this be affected by the said camshaft position sensor?
  • #6 16807090
    DriverMSG
    Help: 3984
    Rate: 4883
    Probably not. Wavy turns are usually "left air" or dirty throttle. However, this is not a rule, so it is worth checking more carefully.
  • #7 16811062
    dawid46stg
    There was a solution, after reading the error codes again, I decided to buy a camshaft position sensor. I replaced it (I am on the right side of the block when we remove the entire lid, the top part with the carburettor and filter). When removing, I noticed that there was one gasket on the manifold and it was "sweaty", so maybe it was catching the left air through it. After replacing, clearing the CHECK ENGINE error, micra goes like a dream, and the error does not appear. The rotation does not wave and does not go out.
The discussion revolves around a Nissan Micra K12 1.2 experiencing issues with hard starting and fluctuating RPMs after ignition, which can lead to stalling while driving. The owner has replaced several components, including the variable phase sensor, lambda probe, spark plugs, and ignition coils, but the problem persists. Error codes P0300 (random/multiple cylinder misfire detected) and P0340 (camshaft position sensor circuit malfunction) were noted. Suggestions included checking the intake system for leaks and inspecting the camshaft position sensor. Ultimately, the owner resolved the issue by replacing the camshaft position sensor and addressing a faulty gasket on the manifold, leading to stable RPMs and no further stalling.
