Audi A6 2.5TDI 180KM quattro - No power up to 2000rpm - log analysis
zonkil 5280 7
  • #1 16448262
    zonkil
    Help: 77
    Rate: 346
  • #2 16449027
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5048
    On what basis do you think the turbo gets up too early?
    I see that the controller wants it earlier, but the turbine reaches the set value only at about 2700 rpm
  • #3 16449254
    zonkil
    Help: 77
    Rate: 346
    I'm sorry too late for the mistake. Maybe the turbine is torn?
  • #4 16449673
    grala1
    Help: 1495
    Rate: 5048
    Unseal the exhaust behind the turbine and see if there is any improvement.
  • #5 16449801
    zonkil
    Help: 77
    Rate: 346
    Catalyst cut out.
  • #6 16449987
    grala1
    Help: 1495
    Rate: 5048
    Check if the coo is leaky, tightness on the vacuum hoses, replace the turbine control solenoid valve, see the vacuum in front of it and behind it at low speed when the coo is pulling to the maximum.
    Once a similar case ended with the replacement of the injectors, it looked as if they were not spraying properly at lower revs, which meant that there was no point in turning the turbine, at higher revs it was better.
  • #7 16450768
    zonkil
    Help: 77
    Rate: 346
    I changed the checked solenoids with the EGR valve and the same effect. I did not measure the pressure of the hoses. The pear is checked, the tightness is ok. I would like to add that the turbo was replaced with the one used from another A6 180KM.
  • #8 16451745
    Olkowski
    Replace MAF or show waveform.
✨ The discussion revolves around an Audi A6 2.5TDI experiencing a lack of power below 2000 RPM. The user has performed several maintenance tasks, including replacing the pump, rollers, and pneumothorax, and checking the vacuum and valves. Despite these efforts, the turbo seems to engage too early, with the turbine reaching set values only around 2700 RPM. Suggestions from other users include checking for exhaust leaks, ensuring the integrity of vacuum hoses, replacing the turbine control solenoid valve, and examining the injectors for proper spray patterns at low RPMs. The user has also replaced the turbo with a used one from another A6 but continues to experience the same issues. A recommendation to replace the MAF sensor or analyze its waveform was also made.
