Is It Safe to Connect Hot Water Directly to a Washing Machine for First Wash?
pols34 50170 13
Can I supply warm water to a washing machine for the first wash without damaging it?
Usually yes, as long as the inlet water is not hotter than the washing program expects; in that case nothing should happen and the machine may simply skip part of the heating time [#8015490][#8016490] On some fully electronic or sensor-controlled machines, very hot inlet water can confuse the control logic or make the program behave oddly [#8015401][#8016490] A practical limit mentioned in the thread is about 40–45°C at the start of the wash; above that, proteins can set into the laundry and the rinse water will also be warm, which is less economical [#8016490] One user reports running a Zanussi with warm water from a boiler and then cold water for rinsing without problems [#8024036] If you want to feed both hot and cold water, a thermostatic mixer or a washer designed for hot/cold connections is the cleaner solution [#16365245][#8016490]
  • #1 8015387
    pols34
    Is it possible to damage the washing machine by giving warm water to the washing machine for the first wash?
  • #2 8015401
    pawel380V
    Level 19  
    Help: 22
    Rate: 71
    It's hard to say how he will react. The washing machine has a sensor to measure the temperature of the water, if it gets hot water, it can "goof"
  • #3 8015490
    kortyleski
    Help: 957
    Rate: 3860
    If only this water is not hotter than assumed in the washing program, nothing will happen. But you will save on electricity because the heater will not have to work
  • #4 8016490
    Romulus7874
    Help: 109
    Rate: 458
    It just depends on what kind of washing machine it is, if some full electronic or one with senses, they can go crazy. Others may shorten the washing program. (Minus the water heating time). Usually it makes no difference, only giving "hot" water over 40-45
    degrees at the beginning of the wash will cut proteins and trap them in the laundry. In addition, the washing machine will also rinse in warm water, which is no longer economical.
    I supply the washing machine with (ordinary) warm water up to 40 *. In the "washing machine area" hot and cold water is supplied. Connected on the wall into one outlet for connection + valves for shutting off one or the other. Simply after loading the washing machine, you wait a while for it to take a hot valve and then on to the cold end. The ideal would be a washing machine with a cold and hot connection.
    Hot water taken from the boiler at 2/3 of its height, so that there is no chance that the washing machine "selects" all the hot water and the temperature is right.
  • #5 8017153
    pols34
    Hello, I also give hot water from the tank for the first wash and then with the myk valve and the rest goes colder but my luna starts to rain after 14 years. Best regards and I am asking for hints.
  • #6 8017591
  • #7 8017620
    pols34
    I give it hot because in winter I have it from the hot water tank and when it burns in the furnace, it can be said that it is for free and in the summer a solar collector
  • #8 8018302
    Piotr Sz.
    Rate: 20
    How about a washing machine factory-adapted to hot and cold water?
    Probably something like that works on the market.
    And the topic is not new ... Link
  • #9 8024036
    wiesiu70
    Help: 6
    Rate: 17
    I have zanussi and I also give it a warm one from the CO boiler and a cold rinse for rinsing, but I watch over when it's over, ladies, I let them go from the beginning because the washing machine shortens the washing time by running time. I guess there are no contraindications.
  • #11 16280761
    viagra1985
    My suggestion is that the water that gets warm from the flue is enough for the initial wash, the next rinse will not heat up much.
    • Is It Safe to Connect Hot Water Directly to a Washing Machine for First Wash? woda.png (25.13 KB) You must be logged in to download this attachment.
  • #12 16365245
    Jerzy Rogala
    And you can connect hot and cold water to a thermostatic mixer? I use it myself (set 30-60 ° C) also to lower the temperature of the water from the tank where the solar water is heated - I have there in the summer to 95 ° C and this temperature is not welcome in the tap :-)
  • #13 16365358
    viagra1985
    Yes, but buying expensive devices or connecting something to electricity generates a cost and in the way I showed, hot water is taken only for prewash (10l), then the next one that flows into the tank will not heat up from the flue and the washing machine rinses in the cold, the same in the case of dishwasher. This is the case in winter and in summer it is enough to paint such a tank black and put outside the water that goes to the devices has a dozen or so degrees more than from the network.
  • #14 17407771
    Theofilos
    Help: 10
    Rate: 27
    What about the parts through which cold tap water normally flows?
    When we connect the hot water tap to the washing machine for the entire laundry, will the hot water not damage something - e.g. plastic elements that may not be adapted to high temperature?
    On bricklayer forum someone wrote that the solenoid valve is not suitable for hot water.
    This question in the context of the very old POLAR PS 663 P BIO washing machine, which is still working, but the heater seems to have fallen.
Connecting hot water to a washing machine can be feasible, but it depends on the machine's design and the water temperature. Most modern washing machines have sensors to manage water temperature, and using warm water (up to 40°C) generally does not cause damage. However, water exceeding 40-45°C can lead to issues such as protein coagulation in laundry and potential malfunction in machines with sensitive electronics. Users have reported successfully using warm water for initial washes, followed by cold rinses, particularly in winter when hot water is more accessible. Concerns were raised about the compatibility of components, such as solenoid valves, with hot water, especially in older models. Brands like Amica and Zanussi were mentioned, with suggestions for machines designed for both hot and cold water connections.
