Unable to Unscrew Metal Valve from Elbow on Cold Water Connection for Dishwasher Installation
KrakowiaczekJeden 57930 7
  • #1 8216128
    KrakowiaczekJeden
    I connect the dishwasher, I have to divide the cold water connection, which until now had only a tap from the faucet. It looks like:
    The problem is that for China I can not unscrew this metal valve from this elbow, I grab the plastic round with a frog, the other for the valve and I turn - NOTHING. Left, right, alone, in two, and nothing. I'm afraid I'm about to tear off the entire pipe. Do you have any advice? It seems to me that this non-woven fabric has swelled so much that it made some groats there.
    (of course, the photo shows the condition before turning off the water and unscrewing this hose from the battery)
  • #2 8216309
    wowka
    Help: 49
    Rate: 247
    Plastic pipes, block the pipe with one key, turn the valve with the other key, if it does not blow, it will break and you will have to replace a piece of plastic pipe. For this you need a heater with the appropriate tips
  • #3 8216498
    KrakowiaczekJeden
    Well, thanks - at least if I break something, I will not panic if it can be fixed somehow without hammering :) but the trash just out of this world.
  • #4 8216660
    Duduś74
    Moderator of HydePark
    Help: 71
    Rate: 225
    There is another way, screw the tee to the valve and you will have the problem solved.
  • #5 8217349
    KrakowiaczekJeden
    In the sense of screwing a tee into the place where this metal tube comes out? It seems to me that the diameter there is too small for it to work effectively, not to mention the fact that I have not seen tees with such a diameter of one of the inlets.
    "Uncle Andrzej" is about to come, a man who can unscrew seized screws from the collectors with his bare hand ;) If he can't, it's just dynamite.
  • #6 8217865
    Romulus7874
    Help: 109
    Rate: 458
    It will be a 3/8 inch tee (ten), plus two nipples. There may be a problem with the sealing of the tee-valve connection. In case of dripping, unscrew and increase the amount of sealing (I recommend hemp / hemp). Select the nipples with an even surface "from the front", in case of unevenness, the surface of the future clamp should be leveled with the hose seal.
  • #7 8220984
    papcio chmiel
    Perhaps a measure for loosening seized parts would help?
    There is one or two companies for sure.
    Description of one of them:
    Loctite 8040 Freeze & Release immediately cools seized and corroded parts (bolts, nuts, studs) to -43 degrees Celsius. C. As a result of the unique thermal shock, many microcracks are formed in the corroded layer, which allows the lubricating components of the product, thanks to their capillary properties, to penetrate deeply. The fasteners can be easily removed after a reaction time of 1-2 minutes.
    I have not tried this method. Perhaps it is effective. If it turned out to be so, write :)
  • #8 15497084
    zbig723
    Rate: 8
    Archaeological topic, but I will share with posterity, because I have just fought a similar situation.
    Faucet on the outside. Ni chu..chu did not walk with wrenches or a hammer and chisel - I tried to hit the nut. Not a small burner - styrofoam and acrylic all around, the plastic pipe started to melt.
    Threaded bathroom descaler.
    After about 10 minutes, he set off with the key (!). It's very hard, but I unscrewed it.
    Internal pipe thread intact. The problem was a bit of muck with tow and stone on the very edge. The new tap came in smooth and works.
The discussion revolves around the difficulty of unscrewing a metal valve from an elbow on a cold water connection during a dishwasher installation. The user expresses concern about damaging the pipe while attempting to turn the valve. Various solutions are proposed, including using two wrenches to stabilize the pipe while turning the valve, and the suggestion to install a tee fitting if the valve cannot be removed. Additionally, a product called Loctite 8040 Freeze & Release is recommended for loosening seized parts. One user shares a personal experience of successfully removing a stubborn faucet using a threaded bathroom descaler after other methods failed.
