Methods for Unscrewing Hemp-Secured Valves in Shower Faucets
kypek 70836 8
  • #1 11233460
    kypek
    Hello, I have a problem because I cannot cope with unscrewing the two valves where the shower faucet is to appear. As you can see, the valves are secured against dripping with hemp. Can someone tell me with what and how I could unscrew these valves?
    Methods for Unscrewing Hemp-Secured Valves in Shower Faucets Methods for Unscrewing Hemp-Secured Valves in Shower Faucets
  • #2 11233561
    Paweł Szeredi
    Help: 12
    Rate: 29
    The easiest way to do this is with a plumber.
    And seriously, these valves have a groove for a flat key or an adjustable key.
    If the valve is to go to the garbage, it can be framed.
  • #3 11233595
    kypek
    I don't know if I named it right, but I have to unscrew the whole nickel-plated part (all the way to the pipe in the wall), not just the (copper?) Key-grooved part. Any new tips?
  • #4 11233618
  • #5 11233654
    kypek
    Oh yeah, I can see it already. There is still the matter of sealing the valve with hemp, it should not be a problem when unscrewing?
  • #6 11233740
    zimny8
    Help: 26
    Rate: 503
    Before you unscrew something, close the main valve, and special eccentric connectors go into the elbows under the faucet, then if the filled boiler is above the future faucet, it will leak out of the cold pipe anyway because it will suck in warm air, so you still need to close the cold inlet valve to the boiler, you get it something?.
  • #7 11235634
  • #8 11236085
    Tommy82
    Help: 455
    Rate: 1074
    It is important how the wall pipe is held because something more can be left in the hand after applying force.
    Such a tap is and with a screwdriver inserted in the output, you can unscrew the base, but it is a bolt or a wrench. And this is how toto holds because sometimes you have to grab two keys.
  • #9 11236660
    Samuraj
    Help: 286
    Rate: 619
    I would suggest using two keys. With one, grab the brass part attached to the wall, and with the other, turn the valve. By turning the valve itself, it may happen that we will screw this brass element. I once did when I wanted to tighten the valve.
The discussion revolves around methods for unscrewing hemp-secured valves in shower faucets. Users suggest using a plumber's wrench or adjustable key to grip the valve's special flattening for counterclockwise unscrewing. It is emphasized to close the main water valve before attempting to unscrew to prevent leaks. Concerns about the hemp seal during unscrewing are addressed, indicating it should not pose a significant issue. Additionally, using two keys is recommended: one to hold the brass part attached to the wall and the other to turn the valve, preventing the brass element from turning unintentionally.
