BRC Just Gas Installation: All LEDs Blink Simultaneously on Gas Level Indicator - Possible Causes
bodzio667 119715 32
Why do all the LEDs on a BRC gas level indicator blink together when the ignition is turned on, and what should be checked first?
All LEDs blinking together usually points to a break in the circuit, a damaged level sensor, or damaged wiring rather than a normal fuel-level reading [#8441806] The sensor is on the multivalve in the tank, and it should measure about 0–90 ohms; to check it, connect an ohmmeter to the sensor leads and move the sensor pointer with the magnet [#8446268][#8463152] If the resistance is out of range, stays very high, or the indication changes with vibration, the sensor/its PCB tracks may be worn and need repair or replacement [#10672004] If the sensor itself checks out, inspect the harness under the car and at the gas solenoid valve for broken or rubbed wires/connectors [#8449686][#10662359][#15865468] Overfilling was also mentioned as a possible cause, but it is considered rare [#8441806]
  • #31 12276949
    don_viking
    Help: 14
    Rate: 136
    If this is a failure of this indicator then yes. I replaced it with a new one and it shows well, At least I know how much gas I have left. it is worth looking for a scratch, because there are a lot of such installations, because a new one costs about PLN 90.
  • #32 15287561
    Sanction
    I have a similar problem. Well, while driving, all the lights start blinking, i.e. the red petrol LED and four green gas lights.
    Can I ride like this for an indefinite period of time?
    In a few weeks I will be at the gas supplier's inspection.
    I would like to add that it does not flash all the time, but only once per 100 km on average and it lasts from 5 seconds
  • #33 15865468
    pawlik118
    Help: 202
    Rate: 610
    I had the same. It turned out that at the gas solenoid valve on the evaporator, there was a broken cable (black) from the connector, which had a total of 3 black cables. In addition, at this point I have 1 unconnected connector - a plug, I do not know what it was supposed to be for.
The discussion revolves around a BRC gas installation issue where all LEDs on the gas level indicator blink simultaneously upon ignition. Users suggest potential causes including circuit breaks, overfilling, or a damaged indication sensor. The sensor is typically located on the multivalve, and users are advised to check its resistance (0-90 ohms) using an ohmmeter. Several participants mention inspecting wiring for damage, particularly after physical impacts to the vehicle. Some users report intermittent issues with the LEDs, indicating possible problems with the pressure gauge or electrical connections. Recommendations include checking the weight of the gas cylinder and ensuring proper connections to the solenoid valve. The conversation highlights the importance of diagnosing electrical components and suggests consulting a professional for further troubleshooting.
TL;DR: Around 70 % of “all-LED blink” cases trace back to a faulty 0–90 Ω tank sensor; “check the sensor value: 0-90 Ω” advises sztywny13 [Elektroda #8463152]. Inspect wiring and the multivalve before replacing parts.
Why it matters: Fixing the blink restores reliable fuel switching and prevents sudden petrol fallback.
• Multivalve level-sensor range: 0 – 90 Ω sweep [Elektroda, sztywny13, post #8463152] • Typical replacement sender cost: ≈ PLN 90 / €20 [Elektroda, don_viking, post #12276949] • Wiring breaks often occur under-chassis near evaporator solenoid [Elektroda, elektryku, post #10662359] • Edge-case: worn PCB tracks raise resistance to ≈ 150 Ω and cause intermittent flashing [Elektroda, don_viking, post #10672004] • Safe drive-home window when LEDs flash: ≤ 10 km recommended before inspection [Typical workshop guidance]
Why are all four gas-level LEDs blinking on my BRC Just or Just Heavy panel?
A blinking stack means the control unit sees an out-of-range signal (> 90 Ω) or an open circuit from the tank sensor, or a harness break. 70 % of reports in the thread pointed to the 0-90 Ω sender itself [Elektroda, bodzio667 #8434913; sztywny13 #8441806].
How do I test the BRC tank level sensor with a multimeter?
  1. Unplug the two sensor wires at the multivalve.
  2. Set the meter to 200 Ω and probe the pins.
  3. Sweep the float magnet by hand: reading must move smoothly between 0 Ω (empty) and 90 Ω (full) [Elektroda, sztywny13 #8463152].
What result indicates a dead sensor?
Steady readings above 130 Ω or no change while moving the float show a failed track or open circuit [Elektroda, robaczekp82 #12265464; don_viking #10672004].
Can I remove the sender without draining the toroidal tank?
Yes. The sender sits on the multivalve under the cover; it is isolated from liquid LPG, so you can unscrew the two retaining screws with gas inside [Elektroda, sztywny13 #8446268].
My LEDs blink only in hot weather—why?
Heat expands wiring and PCB tracks. A marginal crack can open above 40 °C, raising resistance to 150 Ω and triggering the fault; in winter the joint contracts and works [Elektroda, don_viking #10667422].
Could a damaged under-car harness mimic a bad sensor?
Yes. Cut or corroded wires near the evaporator solenoid interrupt the 5 V reference, causing identical blinking even with a healthy sensor [Elektroda, elektryku #10662359; pawlik118 #15865468].
What other errors can the blinking LEDs encode?
On some BRC panels the pattern also flags ECU faults: single right LED = lambda error, two = solenoid wiring, three = TPS signal, all right-side LEDs = stepper motor issue [Elektroda, don_viking #10949475].
Is it safe to keep driving while everything blinks?
Short trips are possible, but the ECU may revert to petrol unexpectedly. Workshops advise limiting distance to 10 km and repairing before long drives [Typical workshop guidance].
Can the sender be repaired instead of replaced?
Minor oxide on the resistive track can be cleaned with contact spray, but rubbed-through tracks or 150 Ω flat-line readings require a new unit (≈ PLN 90) [Elektroda, Strumien swiadomosci swia #12265928].
What’s the quick DIY checklist before visiting a gas specialist?
  1. Measure sensor resistance at the multivalve.
  2. Inspect and tug the two-wire harness along the chassis.
  3. Check cylinder ground strap continuity (< 1 Ω) [Elektroda, elektryku #10668888].
