[Solved] BRC AGS03 Installation Issue: Red to Green LED Change and Four-Time Beep at Car Start
Seraphim79 10155 3
  • Possible BRC AGS03 fault indicated by four beeps
    #1 19558291
    Seraphim79
    Dear all, I have 1y old BRC AGS03 installation, no problem since, but now one occurred. When driving, round controller changed from green led to red and beeped 4 times. After I stopped, turned off engine and started again, it beeped again 4 times, but went green, LPG switched on and I can drive normally. Since then it is beeping like this every time I start car. Any suggestions? I know I will have to go to service, but it is 250km far, so not very close, would be lovely if it was something I could resolve myself. Thanks!
    XMarian
    Help: 7
    Rate: 37
    BRC signals that you have to go to the site for a periodic inspection
    If you change filters yourself, you can go to the site and have this function turned off.
    Jurek0404
    Rate: 24
    That's right. The service signaling as in Stag is set in the program and you can easily turn it off, but then you have to keep an eye on the course between filter replacements.
  • #4 20018267
    Seraphim79
    solved with technician, who forgot to reset date.
