Brc Sequent 24 Installation: Red and Green Reserve Lights Flashing While Driving on LPG
zoom1983 15477 4
  • #1 16442955
    zoom1983
    Installing brc sequent 24. So far it has worked without any problems. The symptom is that when driving on LPG the red and left green lights suddenly turn on (even when the tank is full) and blink. There is no sound signal for switching to petrol, so I am not sure if it is switching to petrol. Anyway, when I press the switch it will switch to gasoline and if I press again it will switch to LPG normally. The problem occurs randomly, with no indication of any particular engine operating condition. I searched the network for error codes signaled by a switch, but nothing fits my case. I am asking for some hint.
  • #2 16501642
    panstalin2
    Help: 30
    Rate: 216
    Check if the hose under the car, which goes with the cylinder tube, is not worn and the rest of the wires.
  • #3 16539842
    Janusz Karkus
    If the switch is round and the red LED is blinking, then the switch is damaged (no contact somewhere on the board, possibly an error in the power supply, battery, fuse.
  • #4 16566706
    logos11
    Rate: 12
    This behavior suggests that the power supply is unstable; but it's controlling. I don't know if you have a signal from the speed sensor or the coil. There, I would look for cold solders or unstable wire connections; also can be rubbing and shortening. Maybe just twisted and insulated sloppy; I do not know. And then you go to the PB because it unlocks the LPG control.
  • #5 16570383
    Janusz Karkus
