Golf IV glow plug light flashing after warm start, no error codes—possible causes?
skartabel 109126 12
Why is the glow plug warning light flashing on a Golf IV after a warm start, and can I identify the faulty part without removing the glow plugs?
A flashing glow plug lamp on a Golf IV usually means a general fault, and in this thread it pointed to the brake-light circuit rather than the glow plugs [#8534116] One reply says to check the stop switch or a light bulb, with the switch located above the brake pedal [#8534711][#8535010] The original poster later confirmed that the brake lights were not working and that one bulb was missing, which fits that diagnosis [#8534581] So the first things to check are the brake bulbs and the brake-light switch, not the glow plugs themselves [#8534498][#8534711] A diagnostic tester was also recommended to confirm the fault code if needed [#8534219][#8534862]
  • Requesting glow plug testing without removal
    #1 8533971
    skartabel
    Rate: 45
    Unfortunately some nice admin blocked me from writing elsewhere than here some time ago.
    I have a problem in golf IV.
    I turn the key halfway, wait for all the lights to go out, then turn it further.
    the car fires up without any problems after 2-3 minutes, the orange indicator looks like a coil, as far as I know it is a glow plug indicator. Then it flashes all the time until the car is turned off.
    What could be the reason
    Is it possible to check which candle is possibly blown without unscrewing them?
    It started flashing for the first time when the engine was hot because I had traveled 50 km and it suddenly started flashing.
    the computer does not show any messages.
  • #2 8533999
    pioart
    Help: 343
    Rate: 1474
    Check the forum for what this light means
  • #3 8534050
    skartabel
    Rate: 45
    Oh, I checked it in the golf IV manual, it's a control for diesel candles, but it was written there that if they are to sweep, the computer shows "manual service" and I only have this light flashing. However, I bet that there is something wrong with these candles.
    polonez15
    Help: 174
    Rate: 898
    Let me tell you that this means a general malfunction of "something", such a check indicator. Look if you got all the stop lights in the beginning (not a joke)
  • #5 8534192
    siewcu
    Help: 133
    Rate: 458
    Someone was moving the immobilizer?
  • #6 8534219
    kubabielsk
    You need to connect the car to the tester, only then can you talk about any errors!
  • #7 8534498
    trans-serwis
    Help: 297
    Rate: 2261
    The reason is probably not candles.
  • Failed brake lights triggered flashing glow plug indicator
    #8 8534581
    skartabel
    Rate: 45
    the immobilizer was not touched.
    from what I know, if it were candles, I would have a problem with firing at a temperature of 2 degrees C.
    However, I fired the shot, it made me think.
    Added after 18 [minutes]:
    The brake lights aren't actually working, and I just checked both of them. Now I have to determine the reason why I hope that only the bulbs have gone, maybe because the indicator light started flashing after braking.
  • #9 8534711
    polonez15
    Help: 174
    Rate: 898
    stop switch or light bulb.
  • #10 8534862
    boozyt
    Level 19  
    Help: 7
    Rate: 94
    hook up to the computer and you will know because such wondering what, where, without checking on the computer, it may take time. in the audi a 3 I had a case that he did not smoke the candles there was a break. so the basis of comp
  • Recommends computer diagnostics for glow plug fault
    #11 8534956
    skartabel
    Rate: 45
    Bulbs are OK, by the way I noticed that I was missing one light bulb :) .
    what is a stop switch ?? understand that it is about a fuse?
    Do you know how much is such a connection to the computer?
    I don't have any mechanics I know, unfortunately, the only friend who went to become a car mechanic worked in the mine, unfortunately he was involved in a stupid sport: /.
    Check brake pedal switch and scan for glow-plug faults
    #12 8535010
    pioart
    Help: 343
    Rate: 1474
    And this is something above the brake pedal.
    For example.
    Any new theories?
  • Check brake switch, bulbs, and scan for fault codes
    #13 8535078
    Michu10
    Level 32  
    Help: 132
    Rate: 755
    Regulations, point 8.1.
The discussion revolves around a Golf IV experiencing a blinking glow plug indicator light, which the user suspects may indicate a malfunction related to the glow plugs. The user notes that the light began flashing after a long drive when the engine was hot, and the vehicle starts without issues. Responses suggest checking the brake lights and the stop switch, as the brake lights were found to be non-functional. There is also a recommendation to connect the vehicle to a diagnostic computer to identify any error codes, as the user has not received any messages from the onboard computer. The user confirms that the immobilizer has not been tampered with and is seeking further clarification on the stop switch and the cost of a diagnostic check.
