How to remove an office chair gas lift – stuck in base/TILT mechanism?
pabloss84 47616 7
  • Request for method to remove stuck office chair gas lift
    #1 8563377
    pabloss84
    I would like to ask you for help and describe the method of disassembling the lift (shock absorber) in the office (computer) swivel chair, it is attached to the base and to the so-called TILT mechanism ... As you probably know, this shock absorber is attached by pressing when folded, but now I can not cope with its disassembly?
    I am asking you to answer as soon as possible how to deal with it
  • #2 8563834
  • #3 8563978
    k-marjo
    No h .. no robot!
  • #4 8564224
    arekb81
    Help: 135
    Rate: 746
    Better get a new chair. One Chinese such shock absorber killed.
    Link
  • Hydraulic press and vise required for stuck gas lift removal
    #5 11739231
    teracos
    Rate: 11
    Hello, sorry for refreshing a bit of a historic theme ....
    Quite an interesting topic, but unfortunately there is little information about it.
    Seats break down and the actuator can be cheaply and easily bought ...
    I also had a problem with the armchair. Actuator lost pressure - frequent malfunction of the seat up and down valve. I analyzed the situation and came to the conclusion that, as a technical person, I would replace the shock absorber / cylinder / strut myself. :idea:
    I bought an actuator for PLN 25 and problems started ... :|
    Well, it's a trivial matter ... you take off what you need, replace the actuator and put everything back together, you don't even have to try too much, because you can't put it together otherwise. :D Unfortunately, according to my observations, without the equipment and a bit of patience, things look rather poor.
    For me, of course, nothing could be painlessly disassembled and the seemingly simple topic turned into a troublesome problem. :| And the spouse's whining that, as usual ...
    Finally, I did so, from the bottom of the chair I took off the pin / washer that fixes the piston-actuator rod - it is such a plate attached around the rod, the end of which can be seen from the bottom in the central part of the stand. At that time, I had a seat that folded out into two elements: a base with a part (housing) of the actuator and a separate backrest with the TILT mechanism and actuator (cylinder plus piston).
    And here, unfortunately, equipment was needed. The oils and the hammer did not help. After two days of efforts (with home methods in the block), I squeezed the sleeve out of the base only on the hydraulic press and tugged the actuator out after a few minutes of struggle with the help of a large table vise, a hammer and a piece of hard rod, Through which I hit the bushing (TILT base) with a hammer sitting on the actuator .
    In my case, the cylinder was completely dead (the piston could be moved with your fingers without resistance), so I was not afraid to screw it into a vice, when the cylinder holds the pressure, I advise you to be careful ... the Chinese mentioned above ....
    I looked at the mounting of the actuator, because I also had the idea that if I do not tear at the vice, I will unscrew the TILT from the seat and from the top (through this sleeve) I will push the actuator on the press with something - it's a bad thing, the "paw" for lifting / lowering the seat is flat for me and there is no access to the actuator from the top ... So the push-out from the top rather comes off.
    I have prepared a simple diagram of what it looks like in my armchair.
    Good luck....
    And, one more thing, the result of my home guerrilla activities is the cracking of the polymer cover of one of the legs of the stand ... I was sure that it was a bit more solid, I leaned the stand against the edge of the table top and tapped the base of the actuator with a hammer - on the first tap, the cover broke. .. and the actuator did not move. I will temporarily stick it with black electrical tape, but in some time the chair will be replaced ... :cry:
    Attachment corrected!
    [_P_]
  • #6 11740348
    Pocieszny
    Help: 229
    Rate: 264
    I have always wondered why it is so easy to put on (in my armchair it is just tucked into the sleeve at the bottom) and so hard to pull out this actuator ;) Even with the actuator partially working, the robot is dangerous and can be hit badly. Even in the instruction manual, they wrote that it was not allowed to disassemble or repair it yourself.
  • #7 11762045
    teracos
    Rate: 11
    Welcome,
    The problem is probably due to the fact that, after all, we sit ... and not only ... sometimes we jump with joy, more often with nerves ... our whole mass focuses on these not very large connections and with time they they press hard .... Hence, you probably need to apply a bit of force to disassemble it ....
The discussion revolves around the disassembly of the shock absorber (lift mechanism) in office swivel chairs. Users express frustration with the difficulty of removing the actuator, which is typically pressed into place. Suggestions include using tools like hammers and chisels, although these may not be effective. Some users recommend replacing the entire chair or actuator instead of attempting disassembly, citing the challenges posed by the pressure and wear on the components. One user shared their experience of purchasing a new actuator but faced difficulties during installation, emphasizing the need for patience and proper tools. The conversation highlights the common issue of malfunctioning actuators and the complexities involved in DIY repairs.
