MAN TGA Pneumatic Chair: Constant Self-Inflation and Sudden Deflation Issue
grzesiek660 21114 9
Why does a MAN TGA pneumatic driver’s seat keep inflating by itself and then suddenly deflate, and how can it be fixed?
The most likely cause is a faulty height-control valve/pump or the seat’s adjustment cables/mechanism, so the seat needs to be removed and checked [#17301603][#16633876][#16635734] If there is no air escaping from the chair, the suggested fix is to replace the valve/pump; one reply says the continuous lifting and lowering disappears after changing that valve [#17301603][#17302389] Worn glides or excessive looseness in the chair mechanisms can also stop it from holding height [#16635210][#16635734] To remove the seat, move it fully forward, lift the flat bar with rectangular holes using a strong flat screwdriver, and pull the seat forward toward the dashboard [#17301603][#17302484]
  • #1 16632308
    grzesiek660
    Help: 14
    Rate: 14
    I set the driver's seat to the lowest height, and he constantly pumps himself up to release the air in a moment and fall down. Is this a common fault, easy to fix?
    darfur5
    Help: 267
    Rate: 1715
    The fault may be typical but you need more description if the chair height can be set without a problem and then miracles happen. Is it a chair Isri or Grammer. Probably the "cross" is embossed or adjustment cables.
  • #3 16635210
    klika60
    Help: 20
    Rate: 278
    They can also be wiped glides and will not hold the height either. You need to remove the seat and check
  • #4 16635678
    kakibara
    Help: 202
    Rate: 1285
    Replacement pump.
    dare23
    Level 19  
    Help: 32
    Rate: 242
    Hello. After removing the seat, you will know more. Sometimes the cables require adjustment and sometimes the reason for this can be a large looseness in the chair mechanisms. If this is a grammer then a small instruction may be useful:
    • Instrukcja Napraw Grammer.pdf (3.72 MB) You must be logged in to download this attachment.
  • #6 17300522
    grzesiek660
    Help: 14
    Rate: 14
    The armchair is ISRI. The height can be adjusted in height, but it constantly pumping up and deflating. How to remove the seat? Maybe some ISRI instruction? I have the impression that the hardness setting is also damaged because there is something too loose about this setting handle.
    kakibara
    Help: 202
    Rate: 1285
    So you didn't replace the pump? It costs pennies, and it starts with it unless you can hear the escaping air connection valve or if you have a rear large pillow it may be damaged gently wiped.
    Move the seat forward as much as possible (of course the seat) into your hand a long flat stronger screwdriver - put it between the seat frame and the handle behind which you moved the seat forward you will see a flat bar with rectangular holes - press the screwdriver against the frame to raise the flat bar pull the seat forward together with a screwdriver. The rest of the cubes or the adjustment cord to uncover but you can handle it?
    Good luck.
  • #8 17302389
  • #9 17302430
    grzesiek660
    Help: 14
    Rate: 14
    Good luck.
    No air escapes from the chair. I do not know if I understood correctly - I should put the screwdriver horizontally above this handle to extend the chair, deny the metal bottom of the seat, push down and pull forward? Pump where is it located? Got it in a SUDER store?
  • #10 17302484
    kakibara
    Help: 202
    Rate: 1285
    You have to raise the profile with holes up and pull the seat forward, i.e. towards the dashboard.
    I don't know if you buy there, you can quickly ask.
The discussion revolves around a malfunctioning MAN TGA pneumatic driver's seat, specifically an ISRI model, which exhibits constant self-inflation and sudden deflation. Users suggest that the issue may stem from a faulty pump, adjustment cables, or worn glides. Recommendations include removing the seat to inspect the internal mechanisms and potentially replacing the pump or valve. Instructions for seat removal involve using a screwdriver to manipulate the seat's adjustment mechanism. The author expresses uncertainty about the pump's location and seeks further clarification on the repair process.
