Creaky Office Chair Solution: Fixing Squeaks in Chinese Allegro Chair with WD
Przemek2802 21390 7
  • #1 17890555
    Przemek2802
    Rate: 119
    Hello. Do any of you have a problem with a squeaky office chair? With every movement in the chair, it creaks mercilessly. Poppicked WD wherever it could ... Chinese armchair with allegro ...
  • #2 17890688
    ArturAVS
    Moderator
    Help: 2303
    Rate: 7847
    Where does it creak? Any photo?
  • #4 17892511
  • #5 17892558
    mieszaczwcz
    Help: 185
    Rate: 258
    Try to use powdered dry Teflon in a spray on the moss and also in the folds of the upholstery
    The use of WD paradoxically intensifies the creaking effect!
  • #6 17892721
    retrofood
    Help: 1140
    Rate: 4800
    Przemek2802 wrote:
    With every movement in the chair, it creaks mercilessly. Popped WD wherever it was possible ...
    Pissing WD to eliminate squeaking sounds reminds me of impregnating the wood with linseed varnish to protect it from vermin. It is actually adding butter to a dry slice of bread.
    Greases are used for lubrication, not WD 40.
  • #7 17894313
    phanick
    Help: 65
    Rate: 2840
    It just so happens that I've been working on this topic recently. In the old 10-year-old violet it started to creak with every harder twist of the four letters on it. It turned out that the weld connecting the socket to the horizontal plate in the tilt mechanism has a fracture almost all around its perimeter. After a few days, it completely fell off.
    I decided to replace the tilt mechanism, but in China it was impossible to knock it out of the pneumatic lift (videos in which the lady smiles twice with a hammer and everything comes out nicely).
    After buying a new tilt mechanism and a new jack, it stopped squeaking for about 3 months and then started again. I suspect that the source of this is either the connection point with the jack again (I didn't put any grease there), or the seat itself.
  • #8 18888494
    Przemek2802
    Rate: 119
    A few days ago the actuator socket twisted and I fell to the ground, it was close to breaking my arm. After putting on a new tilt, nothing creaks yet. The probable place of noise is this dictionary socket, as the previous speaker wrote, there is no factory lubrication there.
The discussion revolves around addressing the issue of a squeaky office chair, specifically a Chinese Allegro model. Users share their experiences and solutions, including the application of petroleum jelly and the replacement of the tilt mechanism, which proved effective for some. However, others caution against using WD-40, suggesting it may exacerbate the creaking. Alternative solutions mentioned include using powdered dry Teflon for lubrication and identifying potential mechanical failures, such as fractures in the tilt mechanism. The conversation highlights the importance of proper lubrication and maintenance to prevent recurring noise issues.
