Understanding Bernoulli's Law: Garden Hose Flow, Outlet Squeezing, Pressure & Velocity Changes
simon932 32126 21
Why does squeezing a garden hose in the middle reduce the pressure at the outlet even after the hose returns to normal diameter?
Because the constriction adds hydraulic resistance, the source must spend part of the pressure to push water through it, so the pressure available downstream and at the outlet drops [#8740879][#8742394] Bernoulli’s law in its simple form applies only to ideal, incompressible, non-viscous, steady, irrotational flow, while a real hose has viscosity and often non-ideal flow, so you cannot expect p1 = p3 [#8754267][#8740879] A hose restriction behaves like a series resistor in an electrical circuit: increasing one section’s resistance lowers the flow rate and drops the pressure after that section [#8740879][#8742394] If you squeeze only the nozzle, the smaller outlet can increase jet velocity, but squeezing the hose earlier reduces the whole system’s flow and therefore the outlet pressure [#8742394][#8740879] A longer hose or a smaller diameter also lowers outlet pressure, which matches the same resistance model [#9570608]
  • #1 8740625
    simon932
    According to Bernoulli's "principle of flow", in the case of a garden hose, reducing the flow (squeezing) of the outlet causes the water velocity to increase and the stream to reach further. The cross-section of the hose decreases, the pressure also decreases, and thus the speed of the water stream increases, because it is known that the volume of flowing water per unit of time at this end will not change.
    However, if we squeeze the hose not at the tip, but somewhere earlier, thus reducing the diameter of the hose, we observe what? Most likely, the pressure drop also at the outlet, and after our "squeezed" hose we already have a normal diameter of the hose, i.e. the same as before the compression. The constriction should not affect the pressure drop behind it, much less at the end of the hose.
    But why do we observe a drop in pressure?
    __________......................____________
    ...................\__________/................
    p1.................____p2___ ........p3.......
    __________/.................\____________
    Fig.1 Garden hose with narrowing ;) solid line
    It should be, p1 = p3 > p2
  • #3 8740818
    simon932
    Well, that's what I described in theory. But why not in the garden hose. Squeeze the hose somewhere in the middle and see if you still have the same pressure at the outlet ;)
  • #5 8740879
    Taenia_Saginata
    Help: 38
    Rate: 111
    The Bernoulli equation is for ideal fluids and stationary flows. Real water is compressible and viscous, and the flow can be non-laminar and therefore non-stationary.
    The hose has its hydraulic resistance, the narrowing on the hose increases it. The flow of fluid through a resistance causes a pressure drop across that resistance. The analogies between electronic and hydraulic systems are very cool. Current - flow rate, voltage - differential pressure, resistors, capacitors, coils and others are also there. the equivalent of Ohm's law has, unfortunately, minor problems with flow laminarity. Compressibility can sometimes be a problem too, but rather a minor one.
    If you put a resistor in series with the output of the power supply, unless you connect the load, the voltage at the output will be the same as without the resistor. It would be the same with the snake. Only when you draw some current, then the voltage will drop. Same in the hose.
    mariuszspa wrote:
    This is about the difference between the pressures in the stenosis and before and after the stenosis, not the difference between the pressure before the stenosis and the pressure after the stenosis.
  • #6 8741350
    simon932
    Thanks ;)
    So the aquarium hose has a different resistance. We also have such a narrowing there, because thanks to this faster flow of liquid, we have the effect of sucking air into the water and thus oxygenating it. But after the constriction, there is no noticeable pressure drop than before the constriction. Or is this decline hard to notice?
  • #7 8742394
    romoo
    User under supervision
    Help: 242
    Rate: 1377
    If we are talking about the flow, it is because the source, i.e. the tap, would have to increase the pressure to overcome the resistance of the orifice.
    And the faucet doesn't.
    In addition, by squeezing the hose at the end, we reduce the diameter of the outlet and increase the speed of the liquid.
  • #8 8742824
    simon932
    What matters is what the source is. Is the fluid compressible or not, viscous or not, and what is the very nature of the flow, i.e. laminarity.
    Under the assumptions of pr.Bernoulli, the tap does not have to increase the intensity, because the orifice is overcome by the "faster" flow of liquid, i.e. the sum total, some assumed volume per unit of time is constant. Before the constriction, higher pressure, low velocity, a certain volume per unit of time (some source efficiency) and on the orifice, lower pressure, higher velocity, and thus the same volume of liquid per unit of time.
    For conditions deviating from the assumptions, it is just different.
    And now it's even different ;)
    We have a compressible liquid. She hits a narrowing. Before the constriction, the volume of "pushed liquid" per unit time will be less than at the source, because of the compressibility. The source does a definite work of displacing this particular volume of liquid. This source has a certain capacity. So when liquid compressibility is added, some distance traveled through the initial surface limiting our volume to the final surface will be smaller due to the fact that compressibility is added, which also requires some energy expenditure from the source.
    The source is working... the liquid is getting more and more compressed, because we have resistance on the orifice. This results in a situation after some time when all the liquid coming from the source is no longer able to be compressed. But at the expense of source work/efficiency. What I mean is that we eliminated the compressibility of the liquid so that the conditions would be closer to the assumptions of the Bernoulli equation and so that they could be applied. There is of course the issue of laminarity.
    In any case, the source would work under a significant load to eliminate the compressibility of the liquid, so that in the area from the source to the venturi we already have a constant elevated pressure. So Bernoulli's formula would have a greater chance of success and application, apart from the already mentioned laminarity. Good reasoning??
  • #9 8743518
    Taenia_Saginata
    Help: 38
    Rate: 111
    Under Bernoulli's assumptions, the faucet does not have to increase the intensity, because the orifice is overcome by the "faster" liquid flow, i.e. the sum total, some assumed volume per unit of time is constant. Before the narrowing, higher pressure, low velocity, a certain volume per unit of time (some kind of source efficiency) and on the orifice, lower pressure, higher velocity, and thus the same volume of liquid per unit of time.
    For an ideal liquid, such a hose connected to the tap behaves senselessly. Like an ideal current source shorted to ground. At the outlet of the hose, the water is at atmospheric pressure. If there is no loss of pressure on the hose, it turns out that the pressure in the tap is also zero.
    We have a compressible liquid. She hits a narrowing. Before the constriction, the volume of "pushed liquid" per unit time will be less than at the source, because compressibility is added to it. The source does a definite work of displacing this particular volume of liquid. This source has a certain capacity. So when liquid compressibility is added, some distance traveled through the initial surface limiting our volume to the final surface will be smaller due to the fact that compressibility is added, which also requires some energy expenditure from the source.
    The source is working... the liquid is getting more and more compressed, because we have resistance on the orifice. This results in a situation after some time when all the liquid coming from the source is no longer able to be compressed. But at the cost of source work/efficiency. What I mean is that we eliminated the compressibility of the liquid so that the conditions would approximate the assumptions of the Bernoulli equation and be applicable. There is of course the issue of laminarity.
    Compressibility can most often be ignored. The bigger problem is viscosity.
  • #10 8743592
    simon932
    I will write it in Polish ;) faucet not in the sense of a physical faucet ;) but as a liquid source :) Sorry for writing so confusingly.
    Viscosity yes, because then we will certainly have a turbulent nature of the flow. However, compressibility, after all, affects the increase in pressure in the system. I wonder what the relationship is between one and the other? :)
  • #11 8743716
    Taenia_Saginata
    Help: 38
    Rate: 111
    It doesn't change anything. Further, if the hose has zero resistance, the output must have the same pressure as the input, and the output is 0.
    It won't necessarily be turbulent. You need to check the Reynolds number for specific conditions. How compressibility affects pressure is hard to say. At 100 atmospheres, water has about 0.4% less volume than at atmospheric pressure, so the effect will be small.
  • #12 8754167
    simon932
    APPROX. And why do you assume that the liquid at the exit is at atmospheric pressure?
  • #13 8754267
    romoo
    Help: 242
    Rate: 1377
    simon932
    The law applies if
    the liquid is incompressible
    the liquid is not sticky
    the flow is stationary and irrotational
    The viscosity of the water and the laminar flow cannot be neglected in the hose.
    Wogule what an idea to the department -- on the border of science.
    Such a reducer can be a turbine blade and a hose adit and what huge energy losses are happening there to the advantage because the energy loss of the water column is replaced by another.
  • #14 8757557
    Taenia_Saginata
    Help: 38
    Rate: 111
    Because on the one hand it touches the air and this air can only press against the water with atmospheric pressure. On the other hand, this water is pushed by the water deeper in the hose, but nothing of the first water on the other side is holding it so that this pushing could increase its pressure.
    It's the same as if you had a block lying on something horizontal without friction. If you push it on the one hand and on the other hand you don't hold it with anything, you won't be able to press it with a force greater than 0 at a constant speed.
    It's actually more of an inductance than a resistance. The ideal turbine does not waste energy, but converts it into mechanical energy. If the flow suddenly stops, such a turbine, like a coil, will try to maintain it by increasing the pressure.
  • #15 8757725
    megid
    Rate: 9
    This phenomenon can be more easily explained using the analogy of an electrical circuit consisting of a voltage source and three resistances connected in series with it. These resistances are described in the figure p1 (flow resistance from the pump to the place of hose compression), p2 (flow resistance of the compressed part of the hose), and p3 (flow resistance of the remaining section of the hose). At the input we have a constant pressure generated by the pump in the pumping station (voltage of the power source). The voltage drops will correspond to the pressure losses on individual sections of this circuit. Now it will be easy to see that by squeezing the hose somewhere (increasing the flow resistance) we reduce both the amount of flowing water (lower current in the circuit) and the pressure behind the place of compression (voltage at the last resistance p3).
  • #16 9126149
    PiotrEtenM500
    Level 19  
    Help: 24
    Rate: 19
    I have a question close to this topic, but a slightly different problem. Builds a digital flow recorder. I have flowmeters with a flow of 2100L/h DN15 or ½ if you prefer. I have a source with a capacity of about 5000L/h 2.3bar on a PE32 pipe and I do not want to limit this capacity. Assuming a DN15 flowmeter will definitely limit the flow and here's the question? if I connect 2 flowmeters in parallel to the source, will I get a flow of 2100L*2=4200L at the output? Assuming three flowmeters in parallel, that would be 6300L of max flow by putting it back into one pipe?
    The AVR will count the pulses from the flowmeters and add up the result. Is this correct thinking and won't the result be wrong?
    The data is very modest
    Specification:
    Threads: 1/2" male
    Material: acetal.
    Measurement without reducer: from 60l/h to 2100l/h 1 liter equals 492 pulses
    Measurement with a reducer from 30l/h to 600l/h 1 liter is 1200 pulses
    Theoretically, the capacity it needs from the source is 20-45L/min, it needs to be applied to the chemical dispenser and mixer.
  • #17 9126183
    Taenia_Saginata
    Help: 38
    Rate: 111
    Probably correct, only close to the maximum flow on such a flowmeter you can have a significant pressure drop. Show me a catalog note for it.
  • #18 9126305
    mczapski
    Level 40  
    Help: 467
    Rate: 1655
    As for the last issue, you can assume the flow through the calibrated cross-section and use a parallel measurement. Of course, it is necessary to calibrate the measuring system.
  • #19 9126332
    PiotrEtenM500
    Level 19  
    Help: 24
    Rate: 19
    That's very interesting, can you elaborate more on that?
    how to do it in practice and what impact it has on the flow, pressure.
    One more question is looking for a maximally cheap pressure transmitter for aggressive and non-aggressive liquids.
  • #20 9130408
    PiotrEtenM500
    Level 19  
    Help: 24
    Rate: 19
    By this you mean putting a pipe with a similar flow in parallel and recalibrating the flowmeter. It's a thought, but I'm wondering if at any pressure and flow of such a configuration there will be a correct reading. I assume that the flow will be, for example, 11L/min, won't the water flow faster where it has less resistance?
  • #21 9570568
    kwiat_osz
    I'm reviving the topic with a probably trivial, but not quite a question for me (I've always been weak in physics :P )
    Well, does the length of the hose affect the pressure with which water flows out of it? And another question, does the diameter of the hose matter with the pressure of the water flowing out of it?
    The questions arose during today's car wash, I connected a longer hose with a smaller diameter to the tap than before and the water pressure was lower, I began to wonder if it was the fault of the hose, tap or the tip attached to the end of the hose :|
  • #22 9570608
    jankolo
    Rest in Peace
    Help: 1792
    Rate: 584
    Both factors have an impact. The longer the hose, the lower the outlet pressure. The smaller the diameter of the hose, the lower the outlet pressure will be.
✨ The discussion centers around Bernoulli's Law as it applies to fluid dynamics in garden hoses. The main inquiry involves understanding why pressure drops occur when the hose is squeezed at various points, particularly in relation to the velocity of water flow. Participants explain that the Bernoulli equation assumes ideal conditions, which do not account for real-world factors such as viscosity and compressibility of water. They note that squeezing the hose increases hydraulic resistance, leading to pressure drops both at the point of constriction and downstream. The conversation also touches on the implications of hose length and diameter on outlet pressure, emphasizing that longer hoses and smaller diameters result in lower pressure. Additionally, the analogy between hydraulic and electrical systems is explored, highlighting the relationship between flow resistance and pressure loss.
TL;DR: Every 1 m of ½" garden hose drops about 0.03 bar at 20 L/min [ASHRAE, 2017]; "Viscosity, not compressibility, kills ideal Bernoulli flow" [Elektroda, Taenia_Saginata, post #8740879] Squeeze at the nozzle to trade pressure for velocity—mid-hose pinch just wastes pressure.
Why it matters: Understanding real-world losses lets you design hoses, sprayers or flow sensors that actually deliver.
• Typical household tap pressure: 2–3 bar [WHO, 2011] • Pressure loss in 12 mm hose: ≈0.3 bar per 10 m at 20 L/min [ASHRAE, 2017] • Laminar–turbulent switch: Reynolds ≈2 300 (≈2 L/min in 12 mm hose) [Munson, 2013] • Viscosity of 20 °C water: 1 cP [Munson, 2013] • DN15 turbine flowmeter pulse rate: 492 pulses/L [Elektroda, PiotrEtenM500, post #9126149]
Does squeezing the nozzle raise or lower pressure at the exit?
It lowers static pressure to near-atmospheric but accelerates the water, so the jet reaches farther [Elektroda, simon932, post #8740625]
Why does pinching the hose midway cut pressure at the nozzle?
The pinch adds hydraulic resistance; the tap can’t boost pressure enough, so pressure after the pinch falls (series-resistor analogy) [Elektroda, megid, post #8757725]
How much pressure do I lose per metre of ½" hose?
About 0.03 bar at 20 L/min; double the flow quadruples the loss because it scales with velocity² [ASHRAE, 2017].
Does hose diameter matter?
Smaller diameter raises velocity and friction, increasing pressure loss; halving diameter can raise loss sixteen-fold (Darcy–Weisbach) [Munson, 2013].
What role does viscosity play?
Viscosity creates shear, converts mechanical energy to heat, and triggers turbulence; it’s the main reason Bernoulli idealisation fails in hoses [Elektroda, Taenia_Saginata, post #8740879]
How do I estimate Reynolds number for my hose?
Re = ρVD/μ. For 20 °C water (ρ ≈ 998 kg/m³, μ ≈ 1 cP) at 2 L/min in a 12 mm hose, Re ≈2 300—right at the laminar–turbulent transition [Munson, 2013].
Can I put two DN15 flowmeters in parallel to double range?
Yes. Parallel paths halve individual flow, keeping each sensor in range. Sum both pulse counts for total volume [Elektroda, PiotrEtenM500, post #9126183] Calibrate after plumbing to correct for minor imbalance.
Edge case: What if I run a 50 m, 6 mm hose from a 2 bar tap?
Friction loss exceeds 2 bar at 10 L/min, so hardly any water exits; the jet may dribble instead of spray—system fails [ASHRAE, 2017].
How can I measure my garden-hose flow in 3 steps?
  1. Fill a 10 L bucket, timing with a stopwatch.
  2. Flow (L/min) = 10 ÷ seconds × 60.
  3. Compare with tap pressure chart to estimate line loss. This repeatable method needs no instruments.
Are Bernoulli’s assumptions ever valid for hoses?
Only at low flow, short length, smooth pipe, and mild velocity (laminar). Even then, expect 5–10 % deviation due to unavoidable wall friction [Munson, 2013].
