Pressure Drop Expectation: 1/2 Inch Garden Hose 50m, 2.5 Bar Initial Pressure, Laid Flat
unky 23034 6
  • #1 15647031
    unky
    What can I expect the pressure drop on the garden hose as in the subject? The hose is laid flat in the garden, pressure at the exit from the cottage - 2.5 bar (1/2 inch connector). These are the ones I have throughout the installation.
    What pressure can I expect at the end of the hose?
  • #2 15647230
  • #3 15648826
    unky
    ok, a decrease in the amount of flow forces me to use a 3/4 hose
    Gentlemen, what about quick couplers and their flows? I will connect two 3/4 hoses with quick couplings. I will buy quick couplings for 3/4 hose, but what is the diameter of the quick couplers? From what I noticed the quick couplings have different diameters for connecting the hose, but the connecting element has a standard diameter independent of the hose diameter. When connecting two 3/4 25 meter hoses, how can I reduce the amount of water flow by connecting the hose with quick couplings?
  • #4 15649658
  • #5 15649935
    unky
    Approximately the size of a 1/2 inch hose, but rather not 3/4 inch
  • #6 15649959
  • #7 15650164
    kkknc
    Nothing. When the hose lies, there is no pressure drop.
✨ The discussion centers on the expected pressure drop in a 50m long, 1/2 inch garden hose laid flat, with an initial pressure of 2.5 bar. It is noted that while the pressure at the outlet remains the same as when the hose is blocked, the flow rate decreases due to flow resistance, which can reduce the flow from 15 liters per minute to around 10 liters per minute. Concerns about using 3/4 inch hoses and quick couplings are raised, with responses indicating that quick couplings do not significantly restrict flow. The potential for flow restriction due to the porosity of the hose and the use of spray tips is also discussed, suggesting that a thicker hose may be necessary to maintain adequate flow.
