Inserting Two Hyperlinks in One Excel Cell for Multiple Movie Titles: A Step-by-Step Guide
DAREK-2 17002 9
Can I put two separate hyperlinks on two movie titles inside one Excel cell?
No, Excel cannot assign separate hyperlinks to different pieces of text inside the same cell; a hyperlink applies to the whole cell or to another object, not to part of the cell text [#16247084] You can only split the movie titles into separate cells, or use text boxes and combine them visually if you really need them to look like one area [#16247084] If you keep one hyperlink on the cell, the other title can only remain plain text [#16247084]
  • #1 8967138
    DAREK-2
    Rate: 103
    I would like to put two hyperlinks in one Excel cell, in which there are two movie titles (see screenshot), but I haven't found a function that would allow it? Do any of you know how to do this?
  • #3 16239788
    DAREK-2
    Rate: 103
    @DriverMSG - sorry that after such a long time, but you can add the link again because I have a 404 error?
  • #4 16240064
    DriverMSG
    Help: 3984
    Rate: 4883
    I corrected the link.
  • #5 16240186
    DAREK-2
    Rate: 103
    @DriverMSG - I did not read it, thinking that it has to do with my question, so if you can make a substantive comment on the topic - I will be grateful.
  • #6 16240206
    DriverMSG
    Help: 3984
    Rate: 4883
    Substantially in the absence of photos, an example?
    Provide a sample Excel sheet in the attachment.
  • #7 16242262
    DAREK-2
    Rate: 103
    In Attachment.
    As you can see in the example, although there are two hyperlinks in one cell, only the first one works.
    And I would like the selected ones to be opened after hovering the cursor over a specific one.
    • Przykład.xlsx (8.22 KB) You must be logged in to download this attachment.
    Maciej Gonet
    VBA, Excel specialist
    Help: 824
    Rate: 481
    That is not possible. The hyperlink is assigned to the cell or to another object as a whole, not to a piece of text in the cell. You can only separate these texts into text boxes and put them together into a cell, or leave one hyperlink assigned to the cell, and the rest to text boxes. But it's a lot of fun. Isn't it easier to separate texts into different cells? After all, Excel has enough of them.
  • #9 16247097
  • #10 16249710
    DAREK-2
    Rate: 103
    @drobok - merging several cells does not give anything, because then Excel sees them as one and if you enter 2 www addresses by default, it sends you to the first hyperlink.
    @-Maciej_ Gonet - maybe it's easier to separate hyperlinks to different cells, but I wanted to be ambitious. ;-)
    Ps. If it is impossible - I close the topic.
The discussion revolves around the challenge of inserting two hyperlinks in a single Excel cell for multiple movie titles. Users express frustration over the limitation that only one hyperlink can function per cell, as Excel assigns hyperlinks to the entire cell rather than individual text segments. Suggestions include using text boxes for separate hyperlinks or merging cells, but these methods do not resolve the issue effectively. Ultimately, it is suggested that separating hyperlinks into different cells may be the most practical solution, despite the user's desire for a more ambitious approach.
