Program for Designing Apartment Electrical Installations: Wire Distribution & AutoCAD Alternatives
Buster 86964 11
Is there software for designing an apartment electrical installation that also lets me draw the wire routes in the walls, instead of doing it by hand in AutoCAD?
There are specialized electrical-design programs, but they usually do not automatically decide the wall cable routes; that part is still typically left to the designer or contractor [#9149897] A close match is SEE Electrical / SEE Building LT Installation Drawing, which can draw installation plans, pull element and line data from a database, update cable lengths when elements are moved, and export building wall contours from AutoCAD [#9149948] PC|SCHEMATIC Automation also has a draft electrical installation plan function with cable lengths, height-based drawing, and parts lists, though its free version is limited [#9150054] Other options mentioned were Planelec, Allplan, MagiCAD, and Autodesk Revit MEP, but the thread suggests none of them fully replace an experienced electrician for route planning [#9150853][#9149897]
  • #1 9149461
    Buster
    Rate: 9
    I am looking for a program to design an electrical installation in an apartment. Specifically, I mean the distribution of wires in the walls. What I found allows circuit design in principle, but not wireform design. There is some such program or AutoCAD remains and drawing everything by hand. :)
  • #2 9149897
    retrofood
    Help: 1140
    Rate: 4798
    From designing the distribution of ducts in the walls, it is the designer or the contractor, not the program.
  • #3 9149948
    elektrocyber
    Help: 8
    Rate: 32
    CAD Electrical SEE Building LT Installation Drawing. Automatically changes cable lengths when elements are moved. You can export the contours of the building walls from AutoCAD.
    http://www.youtube.com/watch?v=vQFq7jrL_V4
  • #4 9149955
    januszbe
    Level 19  
    Help: 28
    Rate: 65
    There remains AutoCad or ... an experienced electrician. I personally have not heard about such a program, it is even better if there is a program that will put these wires, I buy it immediately :) .
    But seriously, how can the program know what the building and / or flat are, etc., what the layout of windows, doors, chimneys, CO and a few more things on the construction site.
    Before you enter this data, I am already halfway there :)
  • #5 9149977
    Buster
    Rate: 9
    I am talking about the program, such as PRO100 for interior design. I draw walls and then I play arranging furniture. I would like the same here. I draw walls and I draw cables.
  • #6 9149988
    elektrocyber
    Help: 8
    Rate: 32
    The PAJAK software, version 2.8, is intended for the design of low voltage installations and their protection in TN networks. Free download.
    If you meant separately.
    http://www.moeller.pl/DesktopDefault.aspx?PageID=355
    Apparently, we automation and computer scientists must stick to help out of nowhere.
  • #7 9150004
    pudzianowski
    Help: 82
    Rate: 127
    And can't there be a program for drawing electronic / electrical schematics or creating printed circuit boards? After adding your own libraries, instead of, for example, a power outlet, you would have a power outlet. Of course, such a solution would require a considerable amount of work to create these libraries. I suggest you read, for example, about the possibilities of KiCAD.
    Greetings.
    Matthew.
  • #8 9150054
    ^ToM^
    Help: 495
    Rate: 2939
    Buster wrote:
    There is some such program, does AutoCAD remain and draw everything by hand.
    There is even a free (probably not the only one) www.pcschematic.com.pl
    He will see if he meets your assumptions.
    The possibilities are:
    "DRAFT ELECTRICAL INSTALLATION PLAN - draw a draft electrical installation plan:
    - drawing the installation plan,
    - information about elements and lines retrieved from the database,
    - cable lengths, drawing at different heights, calculating cable lengths,
    - creating parts lists, updating the table of contents of the project, "
    The limitations are:
    "The provided programs are full versions, with no function limitations. You can draw a simple project, save it and print it.
    PC | SCHEMATIC Automation
    The number of symbols that can be placed in one project (maximum 40) and the number of project pages (maximum 10) are limited. After these limits are exceeded, you can continue working, but you will not be able to save your project. Additionally, the attached database is only a fragment of the database that is commercially available. "
    Simple operation like building a flail, help and documentation from what I associate is "our way".
    I had another one, but now I can't remember the name. It was also free for small projects, they gave me the full cd version at the fair. As soon as I manage to find it at home, I will write it. Maybe someone will still need it.
    Good luck!
  • #9 9150073
    kkas12
    Help: 1076
    Rate: 4313
    Hello!
    Today, projects with marked cable routes are a thing of the past, especially when there is no coordination between industries.
    Most often it is not.
    The location of luminaires and equipment, as well as switching stations, or cable trays, if any, is sufficient.
    The decision on where to route the cables should be left to the contractor (supervision inspector), who will make arrangements with representatives of other industries on the construction site.
    The fact that someone carries these routes is very often "making happy" by force.
  • #10 9150417
    Mad.
    Help: 37
    Rate: 16
    I see people don't read posts well ... To the author of the topic - don't download KiCad, Schematic or Pajak. You won't do what you want in them. Unfortunately, I don't know a program for drawing lines on walls.
  • #11 9150853
    remik_l
    Help: 144
    Rate: 325
    See Electrical, See building, Planelec in these programs you draw lines, but the view is only from the top plan.
    There is an All Plan program where you have a 3D view and it is possible to plan electrical installations, but I don't remember if it is possible to plan cable routes.
    There are also MagiCAD and Autodesk Revit MEP, which are used to design not only cable routes, but also water and sewage, ventilation, fire protection, etc.
  • #12 9151020
    retrofood
    Help: 1140
    Rate: 4798
    Enough.
The discussion revolves around finding software for designing electrical installations in apartments, specifically for wire distribution within walls. Users express frustration with existing programs that primarily focus on circuit design rather than detailed wire routing. Suggestions include CAD Electrical for its ability to adjust cable lengths dynamically, and PAJAK software for low voltage installations. Other mentioned tools include See Electrical, See Building, Planelec, All Plan, MagiCAD, and Autodesk Revit MEP, which offer varying capabilities for planning electrical installations, though some limitations exist regarding 3D views and detailed wire routing. The consensus indicates a lack of dedicated software that meets the specific needs of wire distribution design.
