What is the single-line diagram of the installation for power-up to look like
mlodaada 69908 4
  • #1 1890128
    mlodaada
    Zakład Energetyczny, in the conditions of connecting the electrical installation to the apartment, in which, after removing the electricity meter, I applied for re-installation, stated that a single-line design should be drawn up from the meter strip in the staircase to the WLZ, along with the preparation of the WLZ. The WLZ is adapted because it has recently been replaced and in the box I have my pre-meter fuse with the apartment number. How such a diagram should look like and whether it should be handwritten or in Autokada, and what permissions should the person signing as the contractor of the diagram and installation have.
  • #2 1892956
    waldekel
    Help: 63
    Rate: 477
    Fill in the application for technical verification, specified by the connection conditions, and also prepare a single-line diagram there, for which installation measurements must be included. These activities are performed by a licensed electrician who knows how to do it. There is no other alternative, because the power industry will not connect.
  • #3 1899917
    jozefg
    Help: 197
    Rate: 746
    mlodaada
    If you think that an electrician will help you, you are wrong :cry:
    They only get smart on their forums - but to help someone?
    For a month now, I have not been able to ask for the same :cry:
  • #4 1901202
    ekaand
    Help: 37
    Rate: 165
    And here you are wrong jozefg .Tell what you need and if possible, if I can, I will help.
