Connecting Two Monitors with Varied Resolutions to a Single PC
trocero77 36521 7
  • #1 9158186
    trocero77
    Help: 9
    Rate: 8
    Is it possible to connect 2 different monitors to a PC so that the image in each of them is displayed in a different resolution at the same time?
    Perhaps there is a applet that makes it possible.
    I would be grateful for any suggestion.
  • #2 9158188
    among
    Help: 146
    Rate: 99
    There is a possibility. This is possible thanks to the graphics card program.
  • #3 9158197
    trocero77
    Help: 9
    Rate: 8
    Refines the query.
    I only know that this option is:
    - one monitor is set to 1080x1920 resolution
    - the second has a maximum resolution of 1366 x 768
    - if I set the display of the image on both monitors, it does not work due to the inability to display HD image by the second monitor (the one with lower resolution). I want the image to be seen in one monitor in HD and in the other in native resolution.
    I know that if I set the monitor (the one with HD) to a lower resolution (the native of the second monitor) it will work like that. "Fun" consists in displaying 2 different resolutions.
  • #4 9158216
    among
    Help: 146
    Rate: 99
    Of course you will set one to 1920x1080 and the other to 1366x768.
    On the first screen you choose 1920x1080, and on the second screen (I don't have it connected) you choose 1366x768
  • #5 9158246
    trocero77
    Help: 9
    Rate: 8
    Well, I did that too, and nothing like that. The lower resolution monitor goes blank and that's it.
  • #6 9158257
    among
    Help: 146
    Rate: 99
    If the drivers for the card are installed correctly, it must work. So far I have used two monitors and there was no problem.
  • #7 9160186
    trocero77
    Help: 9
    Rate: 8
    I will look again and let me know.
  • #8 9326948
    trocero77
    Help: 9
    Rate: 8
    And it worked. But only after updating the driver for the ION platform. Both monitors work with different resolutions. I close the topic.
Connecting two monitors with different resolutions to a single PC is feasible, provided the graphics card drivers are correctly installed. Users can set one monitor to 1920x1080 and the other to 1366x768. However, issues may arise if the lower resolution monitor cannot display the HD image, leading to a blank screen. A successful setup was achieved after updating the driver for the ION platform, allowing both monitors to function simultaneously at their respective resolutions.
