ATI Radeon 3000 - No 1920 x 1200 resolution and desktop extension mode
datalux1 12045 16
Why did Windows 10 switch my ATI Radeon 3000 to Microsoft Basic Display Driver and remove 1920x1200 plus dual-monitor extension mode, and how can I fix it?
Windows 10 is falling back to Microsoft Basic Display Driver because the Radeon 3000 no longer has proper AMD support on Windows 10, so after updates the system may lose higher resolutions and second-monitor detection [#16845763][#16845982][#16846110] Try turning off Quick/Fast Boot in the BIOS and install a Windows 10-compatible OEM AMD driver package for the motherboard/GPU, such as the ASUS/MSI driver links posted in the thread [#16846032][#16849276] If the card still stays on the basic driver and the second display is not detected, the thread’s practical conclusion is that this older hardware is not fully supported and the real fixes are either to use a different Windows version or replace the graphics card with a newer PCI-E model [#16854455][#16854458]
  • #1 16844084
    datalux1
    Rate: 9
    I have an ATI Radeon 3000 graphics card and two monitors probably the same DELL U2410 model. One of the monitors is connected with an HDMI cable and the other with a VGA cable. I tried to connect the second monitor with the DVI cable but then there was no image. The operating system is Windows 10 64 bit. I was working on a computer and for some time it was fine until the modes suddenly changed. It turned out that there is no 1920 x 1200 resolution and no desktop extension mode. When you go right-click on the desktop -> Display settings -> Display display properties, in the "Card type" section there is a "Microsoft Basic Display Driver" driver written so it looks like a standard driver and I think there should be a driver from ATI Radeon 3000. In the screen settings as the "Detect" button is pressed in the "Multiple screens" section, it says "No other screen detected". As the windows key is pressed and P says "Display on another screen. The computer cannot use another screen. Try reinstalling the driver or use a different video card". When you enter the control panel -> device manager, the graphics cards have the correct "ATI Radeon 3000 Graphics" driver that was downloaded from Windows Update because in Windows 10 64 bit there is no support for this card from the ATI manufacturer because it is an older card. The version of the driver "ATI Radeon 3000 Graphics" is 22.19.128.0 from 07/25/2017. In the device manager next to the monitors there is only one driver "DELL U2410 (HDMI)" in version 4.0.0.0 from 07/06/2012 so it seems that there should be two drivers since there are two monitors. The operating system has been updated with Windows Update. Why is there no 1920 x 1200 resolution and desktop extension mode available? How to fix it ?
  • #2 16844578
    jarasnet
    Rate: 14
    I have something similar from today. After coming from work and starting the computer, a total mess on the desktop and the resolution set to
    1280 x 1024 and that's the max! Oddly enough, in the card's properties it says "no drivers installed" and when I click "update driver", something like that you already have the best possible driver (shows 22.19.128.0)! Wtf?
    Can you download something from here ?:
    https://www.driveridentifier.com/scan/ati-rad...036A1A2BBF9F7ECB135/PCI%5CVEN_1002%26DEV_9616
    But what?
  • #3 16845527
    datalux1
    Rate: 9
    When you enter the device manager in the control panel and select the properties of the graphics card, in the "general" tab in the "Device status" section it says "No drivers for this device installed". The "Restore driver" option is disabled. After searching the net, I found only windows 8 64 bit for windows 10, they are not there, I tried to install them for windows 8 but they cannot be installed due to incompatibility with the operating system version after entering the device manager and graphics card properties in the general tab in the section " device status "writes with" No drivers for this device installed ".
    In the screen settings where there is the "Microsoft Basic Display Driver" driver in the card properties in the "Events" tab it is written:
    [10:30]
    23.11.2017 14:55:12
    [10:30]
    Zmigrowano urzadzenie
    [10:30]
    Device ROOT\BasicDisplay\0000 was migrated.
    Last Device Instance Id: ROOT\BasicDisplay\0000
    Class Guid: {4D36E97D-E325-11CE-BFC1-08002BE10318}
    Location Path:
    Migration Rank: 0x0
    Present: true
    [10:30]
    23.11.2017 14:55:12
    [10:30]
    Skonfigurowano urzadzenie (basicdisplay.inf)
    [10:31]
    Device ROOT\BasicDisplay\0000 was configured.
    Driver Name: basicdisplay.inf
    Driver Date: 06/21/2006
    Driver Version: 10.0.16299.15
    Driver Provider: Microsoft
    Driver Section: MSBDD_Fallback
    Driver Rank: 0xFB0000
    Matching Device Id: ROOT\BasicDisplay
    Outranked Drivers:
    Device Updated: false
    Parent Device: HTREE\ROOT\0
    [10:31]
    23.11.2017 14:55:12
    [10:31]
    Uruchomiono urzadzenie (BasicDisplay)
    [10:31]
    Device ROOT\BasicDisplay\0000 was started.
    Service: BasicDisplay
    Lower Filters:
    Upper Filters:
    Are there any ways to fix the problem?
  • #4 16845763
    safbot1st
    Help: 2719
    Rate: 1585
    datalux1 wrote:
    ATI Radeon 3000
    It is not the name of a model but a series.
    Do you have motherboards, gentlemen, and current BIOSes in them?
    Please the 3rd CPU-Z tab and 1st GPU-Z tab.
    Any power supplies for this? Can you know what?
    "Fast Boot" / "turbo boot" or BIOS equivalent is it? Turn off.
    Lack of support means "there will be problems" for short, and there are.
  • #5 16845893
    datalux1
    Rate: 9
    The motherboard is M5A78L-M / USB3 and it is loaded with the current BIOS version 2101. I have attached a screenshot of the CPU-Z and GPU-Z software below.
    In Bios I found the "Quick Boot" option in the "Boot" tab and it is enabled.
    The computer is not mine so I will not enter the BIOS to set the "Quick Boot" option because it is too big a risk.
    I do not know what the power supply is.
  • #6 16845982
    kmikos168
    I also try to fight this problem, the fault is with the system update and the lack of current AMD drivers. This topic has already appeared on foreign forums, but I haven't found a solution yet. Ways to solve the problem on the manufacturer's website, such as installing an older version of the system or buying a new card, do not help much either.
  • #7 16846018
    mateu16
    I had a similar on the radeon, I don't remember exactly but I had to play with changing the resolution in windows (desktop resolution) and then in catalyst. I guess I changed to the lowest desktop, then in Catalyst and then the desktop chapter was unlocked and then in Catalyst. Preferably on one screen.
  • #8 16846032
    safbot1st
    Help: 2719
    Rate: 1585
    It's nice that I'm looking for a PCI-E "card", then I get it
    M5A78L-M / USB3
    Listen? There is no risk. This is the basic thing you switch if there are problems with detecting your monitors.
    Either you "fix" or you make fun of me. Have the motherboard owner change this option.
    It's hard to comment on that.
    Here:
    https://www.asus.com/pl/Motherboards/M5A78LMUSB3/HelpDesk_Download/
    also no vga driver? For me, it has absolutely nothing - maybe through Linux browsers.
    Added after 5 [minutes]:
    ps. There is also no W10 support for AMD:
    http://support.amd.com/en-us/download
  • #9 16846069
    datalux1
    Rate: 9
    I turned off the "Quick Boot" option in the BIOS but it still doesn't detect the second monitor so I turned it back on. The graphics card is integrated into the motherboard.
  • #10 16846110
    safbot1st
    Help: 2719
    Rate: 1585
    I know. Unfortunately no "AMD" support for this GPU for the W10 ...
  • #12 16849309
    Matuzalem
    Help: 1653
    Rate: 1101
    I would not like to be a bad prophet, but - not only with regard to AMD - "something has happened" with the "older" cards on the line system - graphics driver after the recent Windows 10 updates and what previously allowed to achieve different resolutions about options is no longer available.
    It looks like you either have to be under the delusion that the producers will match the drivers or accept it.
    Besides, it is not only a question of resolution - there are problems with recognizing the card (nVidia - various models) for distributed computing (BOINC - SaH) and the inability to download packages for graphics, which was not a problem before.
    PS
    It seems that the cooperation between Microsoft and component manufacturers is so close that they agree * on compatible - read: more and more required - hardware.
    * I also allow myself the census theory.
    Doradztwo podatkowe
    Wilczyńskiego 25/13, Olsztyn, 10-686
  • Asking whether driver updates can fix resolution issue
    #13 16854445
    jarasnet
    Rate: 14
    DriverMSG wrote:
    Fear of normally asking not to land in the bin, but are these packages to help solve the problem?
    Is the problem at all solvable by installing / updating something or should I go buy a new motherboard?
  • #14 16854455
    safbot1st
    Help: 2719
    Rate: 1585
    As for the first question, it must be checked.
    As for the second, no one will tell you to buy a new one, since you have other options - buying a budget card for PCI-E or changing the OS. :(
  • #15 16854457
    DriverMSG
    Help: 3984
    Rate: 4883
    These are drivers compatible with the above identifier and Windows 10.
    Will they solve the problem? I don't know, because I would have invested in a better graphics card a long time ago.
  • #16 16854458
    safbot1st
    Help: 2719
    Rate: 1585
    Pretty stupid idea, but you can always try the BIOS downgrade for a change.
  • #17 16902185
    jarasnet
    Rate: 14
    Today, after the strange behavior of the screen (blinking, black screen, blinking again) the resolution automatically returned to 1440x900. I absolutely do not know how it happened but I'm happy about it!
The discussion revolves around issues faced by users with the ATI Radeon 3000 graphics card, particularly regarding the inability to achieve a 1920 x 1200 resolution and the failure to extend the desktop across two monitors (DELL U2410). Users report that the system defaults to the "Microsoft Basic Display Driver," indicating a lack of proper drivers. Attempts to update drivers have been unsuccessful, with users encountering compatibility issues with Windows 10. Suggestions include checking BIOS settings, disabling "Quick Boot," and exploring driver downloads from various sources. Some users speculate that recent Windows updates may have affected driver support for older graphics cards, leading to resolution and detection problems. Alternatives discussed include downgrading the BIOS or considering a new graphics card.
TL;DR: If your Radeon 3000 on Windows 10 lost 1920×1200 and Extend display, check drivers: version 22.19.128.0 (2017‑07‑25). “In Windows 10 64 bit there is no support for this card.” [Elektroda, datalux1, post #16844084] Why it matters: This FAQ helps Windows 10 users with ATI/AMD Radeon 3000 iGPU regain native resolution and dual‑monitor modes.
How do I restore 1920×1200 and Extend display on Radeon 3000 in Windows 10?
Install an OEM Radeon driver, reboot, then re-enable multi‑monitor. If Windows still shows the Basic driver, install the shared ASUS/MSI/Dell packages, then AMD chipset, and reboot. If detection fails, disable Fast/Quick Boot in BIOS and cold‑boot with only one display, then add the second. Finally, confirm Device Manager shows “ATI Radeon 3000 Graphics,” not Microsoft Basic. [Elektroda, DriverMSG, post #16849276]
Why does Windows suddenly cap at 1280×1024 or drop my second monitor?
Windows may fall back to Microsoft Basic Display Driver after an update, limiting resolutions and multi‑display features. Users reported maxing out at 1280×1024 until a proper Radeon driver was installed again. “No drivers installed” can appear even when Windows Update says the driver is best. [Elektroda, jarasnet, post #16844578]
What does “Microsoft Basic Display Driver” mean here?
It means Windows is using a fallback driver, not the Radeon 3000 vendor driver. In Events, you might see basicdisplay.inf with service BasicDisplay. That mode restricts resolutions and often disables Extend. Replace it with the Radeon 3000 driver and reboot. [Elektroda, datalux1, post #16845527]
Does AMD officially support Radeon 3000 on Windows 10?
Participants note AMD’s Windows 10 support for this legacy iGPU is absent. “Lack of support means ‘there will be problems’.” Expect instability after updates and limited features without OEM‑tuned packages. Consider a discrete PCIe card or different OS if stability matters. [Elektroda, safbot1st, post #16845763]
Which drivers should I try first?
Start with the shared OEM bundles: ASUS/ MSI display drivers, Dell’s legacy AMD package, and the AMD chipset driver. Install display, reboot, then chipset, reboot. These builds restored proper detection and modes for some systems. Keep only one package if one works to avoid conflicts. [Elektroda, DriverMSG, post #16849276]
How do I install the driver if Windows says the best one is already installed?
Use Device Manager: Update driver → Browse my computer → Let me pick → Have Disk → point to the OEM package folder. If blocked, uninstall the device (check “Delete the driver”), reboot, and install again from the OEM package. [Elektroda, DriverMSG, post #16849276]
What is Catalyst Control Center, and can it help?
Catalyst Control Center is AMD’s panel for display modes. One user regained options by lowering Windows desktop resolution, changing settings in Catalyst, then raising resolution again. Try this on a single monitor first, then add the second. [Elektroda, mateu16, post #16846018]
Should I change BIOS settings like Fast/Quick Boot?
Yes. Disable Fast/Quick Boot to improve display detection during POST and handoff. An expert advised turning it off when monitors aren’t detected. Re‑enable only after stable operation returns. This simple toggle often helps legacy GPUs. [Elektroda, safbot1st, post #16845763]
Is downgrading the motherboard BIOS worth trying?
It’s a last resort. One suggestion was to test a BIOS downgrade if newer firmware worsened compatibility. Proceed only if you can safely recover the board and have a known‑good prior version. [Elektroda, safbot1st, post #16854458]
Could the integrated Radeon 3000 be the limitation?
Yes. The GPU is integrated on boards like the M5A78L‑M/USB3. Output combinations and clocks can be limited versus modern cards, especially under Windows 10 without official support. A low‑cost PCIe GPU is a practical upgrade path. [Elektroda, datalux1, post #16846069]
What quick 3‑step fix should I try first?
  1. Disable Fast/Quick Boot in BIOS, power down, leave one monitor connected.
  2. Install an OEM Radeon driver package, reboot, confirm Device Manager shows Radeon 3000.
  3. Connect the second monitor, set Extend in Display settings, then fine‑tune in Catalyst. [Elektroda, DriverMSG, post #16849276]
What edge cases should I expect after Windows updates?
After updates, displays can blink and revert to lower resolutions unexpectedly. One user’s system fell back, then later auto‑returned to 1440×900 without explanation. Keep driver installers handy and create a restore point before big updates. [Elektroda, jarasnet, post #16902185]
Is buying a new GPU the most reliable solution?
Community advice leans toward a budget PCIe card or changing OS if drivers keep breaking. That avoids time‑consuming reinstalls on unsupported hardware. Evaluate cost versus repeated downtime. [Elektroda, safbot1st, post #16854455]
Where do I see the exact driver version and date?
Open Device Manager → Display adapters → Radeon 3000 → Properties. Users reported version 22.19.128.0 dated 2017‑07‑25 in affected systems. If you see Microsoft Basic Display Driver instead, your vendor driver isn’t active. [Elektroda, datalux1, post #16844084]
Why doesn’t DVI show an image while HDMI/VGA works?
When the Basic driver loads, digital outputs may fail to initialize or expose limited modes. Ensure the Radeon driver is active, then test DVI alone at boot. Add the second display only after the first works at native resolution. [Elektroda, datalux1, post #16844084]
What’s a realistic outcome on this legacy platform?
With OEM drivers and BIOS tweaks, many regain native resolution and Extend mode. However, stability can regress after Windows updates. “There will be problems” succinctly captures expectations for unsupported GPUs. Plan for a discrete GPU if reliability is critical. [Elektroda, safbot1st, post #16845763]
