Adjusting Screen Resolution on TeamViewer Without Connected Monitor
incorsklep_pl 8157 4
  • #1 16551383
    incorsklep_pl
    I haven't found an answer to my problem anywhere, so let me ask.
    I use one of the computers as a server but only connect to it once in a while via Team Viewer. No monitor is connected to the graphics card.
    After Team Viewer is connected, the screen works in 800x600 resolution.
    I want to change the resolution to a more affordable one, but since no screen is detected, I can't change the resolution.
    Anyone know how to do this?
    I will be grateful for your help.
    wroLED
    Grota Roweckiego 168, Wrocław, 52-019 | Company Website: www.wroled.pl
  • #2 16552660
    enhanced
    Help: 963
    Rate: 883
    Do you use Team Viewer or VNC? Was it not visible outside?
  • #3 16553925
    incorsklep_pl
    Team Viewer.
    After connecting the monitor to the hdmi, the card changes the resolution to the one I want, and after disconnecting the moitor, it returns to low resolution.
    wroLED
  • #4 16893378
    h999
    In TeamViewer advanced options I found monitor driver installations, installed and I don't know what to do next. After turning off the monitor, the resolution changes, maybe someone knows what to do next to set your own resolution without the monitor.
  • #5 16893723
    enhanced
    Help: 963
    Rate: 883
    https://community.teamviewer.com/t5/Knowledge...-use-TeamViewer-on-headless-systems/ta-p/4256
    Please make sure to connect a graphics display to the device. It may also be sufficient to connect a dummy plug to your graphics card.
    Maybe connect the cable itself to the graphics card without connecting any monitor?
    With this monitor driver, I don't know - I haven't tested what it gives.
